Question about Canon Digital SD900 / IXUS 900 Ti Digital Camera
Canon ixus 900 ti red eye
I have a problem with the red eye, most photos that i take there is always red eye even when i have the red eye reduction on. was wondering if anyone had a solution.
  • 1 more comment
  • venus6c Oct 23, 2008
    i have a problem with the red eye, most photos that i take there is always red eye even when i have the red eye reduction on. was wondering if anyone had a solution.i have a problem with the red eye, most photos that i take there is always red eye even when i have the red eye reduction on. was wondering if anyone had a solution.
    Canon ixus 900 ti red eye problem. I have completely the same problem in my canon ixus 900 TI red eye problem although I have the red eye reduction "on" and there is no red eye reduction flush appear on the screen. Please help me to solve this problem. I really appreciate if anyone can give me the solution. HELP!
  • Anonymous Dec 17, 2008
    Every photo I take with the flash on has red eye even with the red eye reduction.
Hi Dont know how to fix the red eye and neither did cannon so i ended up with a refund!
Cheers Garry
Posted on Oct 28, 2008
SOURCE:
I have a Canon SD 790 and have tried everything to get the red eye reduction function to work. Problem is, I don't have my manual and can't find it in the 227 page download! I have looked through the tools...
Red eye reduction doesn't work that well on cameras. You would be better off importing your photos into a program like Picasa and fixing the red eyes there. Picasa's red eye removal is one of the best out there and very simple to use.
What you could also try is diffusing the flash somewhat. Put a piece of tissue paper over your flash is one way to do it. Or try bouncing the light from the flash off the ceiling with a piece of card (I've even used a piece of torn paper plate to do this)
Aug 28, 2013 | Canon PowerShot SD790 IS/ IXUS 90 IS...
There is a lot of red eye on the photos ,please help.I cannot find a red eye reduction button on the camera.
I don't know whether this camera has red-eye reduction. It is likely to be found in the setup for the flash, or as a toggle for the flash setting. On some cameras, you toggle through the available flash settings until the icon (usually a lightening bolt) has an eye next to it.
Red eye reduction is not perfect even if the camera offers it. You get a much better solution by using a photo editing program in the computer to remove red eye from your shots. Many such programs have a function just for this that works almost automatically. You may have gotten a photo editing program with the camera, but there are many others downloadable for free on the net, try www.download.com.
Nov 03, 2010 | Nikon Coolpix S3000 Digital Camera
I have a HP Photo Smart R707 with a fully charged new battery and the flash won't work. Keep getting charging flash. Any help on this?
The flash mode has to be set.
There are 5 flash modes:
  • auto - flash fires when needed
  • red-eye reduction - flash fires when needed, but there's a pre-flash to minimize red-eye
  • flash on - flash always fires
  • flash off - flash never fires
  • night - flash fires if necessary (and uses red-eye reduction) to illuminate foreground objects, but shutter stays open to record the background by ambient illumination
http://www.bobatkins.com/photography/digital/hp707.html
Aug 11, 2010 | HP Photosmart R707 Digital Camera
Even with the red eye reduction function turned on I still get red eye----why
Red eye happens because the flash is close to the lens. Even with the red eye reduction function, you're still going to get some. You can either use off-camera flash, or correct it in software.
Dec 30, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
How do you activate red eye reduction in the 5900?
To take photos with red eye reduction requires your flash to firerapidly before snapping the pic. Make sure camera is in record mode pres the 4 way switch with the lightning sign on it. The flash modes will pop up. select red eye flash.
To fix red-eye after a photo is taken. Bring up the photo in playback mode and press menu button. Red eye reduction should be available as one of the menu items. Otherwise, display the pic, press OK button in center and if you like the fixed picture then select yes to store it.
Jan 12, 2009 | Nikon Coolpix 5900 Digital Camera
Red eye reduction
while in record mode, press the flash/up button repeatedly until you are in red-eye reduction mode. red-eye reduction mode should greatly reduce the problem when enabled. If this does not work, the software that came with your camera (and most photo editing applications) include a red eye reduction/removal filter.
hope this helps,
trin
Nov 17, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Red-Eye Fix
Here is a link to the product manual: http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 It states that to turn on red-eye reduction mode (p.43), go to the Camera menu, then set the top setting (red-eye) to "on". Even if you are unable to get this to work (or if you do get it to work, but are unhappy with the results), there is a really nice free proto organizer (www.preclick.com) that includes a red-eye removal tool that is really simple to use.
Feb 11, 2007 | Canon PowerShot A520 Digital Camera
Red eyes
As both the camera and the flash does not have red eye reduction facility, you can solve the problem by not using high speed film, i.e. not more then 100 ASA and avoid shooting in very low light.
Oct 30, 2006 | Vivitar 2800 Flash
DSC-P72 using Flash
Hi, While I do not have a P72, I find this problem odd. Most flash cycle times are so rapid that your grandaughter could not possible close her eyes in that time period (the travel time for the flash to fire and be reflected from the child's face is far faster than a human blink). The problem may be in pre-flash and not the flash itself. So that redeye-reducing "feature" may be responsible for your problem. Does your camera have a redeye reduction mode on the flash?
Sep 13, 2005 | Sony Cyber-Shot DSC-P72 Digital Camera
Canon Digital SD900 / IXUS 900 Ti Digital Camera Logo
93 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
