Question about HP 500VA UPS System
Cannot find a replacement fuse for an HP UPS model#R12000. UPS needs fuse replaced. Found a company that will do the manual labor but cannot find fuse part number.
2 Suggested Answers
SOURCE:
  • 8457 Answers
SOURCE: HP LC4776N power supply problem
Tries websites like Shopjimmy.com,Ebay.com to research refurbish power supply board to buy.
Posted on Jul 21, 2010
Hi, I have a Manhattan Line Interactive UPS Model #168120 that needs a new battery. Is it replaceable in this unit? Thanks.
The battery is listed as replaceable. However, Manhattan indicates that the battery is not user-servicable. Since the company no longer seems to sell any UPS, getting it serviced may not be possible.
A copy of the manual is available here: http://www.comtekcomputers.com/manual/html/168120_manual.html . The relevant section is part of the trouble-shooting guide: "The battery is old or bad. Return for service."
I wish that I had better news for you.
Aug 22, 2011 | Computers & Internet
Need upsmon software for windows 7
Go to this link: http://www.nodevice.com/driver/company/Mustek/UPS.html
It lists a few model numbers for Mustek UPS system, select the model that is the same as yours and follow the download instructions.
Rate me high if you found this helpful.
Thanks.
Nov 01, 2010 | Mustek Computers & Internet
Have a UPS R12000 XR system, It show 1 alarm on the MM which indicates (emergency power is off). Does this require replacing the Main Module.
maybe yes, maybe not, have it check by an electronic repair center, there are no user serviceable parts inside, or you might end up messing the whole unit instead of the real damaged part,
Jun 02, 2010 | Compaq UPS R12000 XR (207552-B22) UPS...
How much are tune-ups for my trailblaizer
Spark plug run about $12.53 each X 6 Double Platinum
Labor to remove and replace only spark plug's
1.6 hour's X there labor rate = labor cost.
To also replace air filter and fuel filter
air filter about $20.69
fuel filter about $37.41
Labor to remove and replace .7thent of an hour
May 19, 2010 | 2002 Chevrolet TrailBlazer
Hi we have problem with 6kva 9120 eaton ups,
Maybe you have many overvoltage situations at your area, that the UPS can't handle. It's a good idea to put before the ups an overvoltage protection or a stabilizer. Ask the manufacture for the overvoltage protection of the ups that can handle.
Stelios.
Feb 22, 2010 | Eaton Powerware® 9120 UPS System
Evaporator coil needs to be replace again. Installed w new manufactured home; 09/2005. Replaced 05/30/08. Needs to be replaced again 09/17/09. All due to leaks. Freon was added. Currently has small leak;...
the manufacture is only required to supply the part free of charge thru its warranty period. the installing company probably would only give a 1year labor warranty and honor the pparts thru the manufacture for 5 years but unless you paid additinal for an extended labor warranty i dont think you are going to have much luck. Make sure you change your air filters every 30 days a dirty filter is one of the biggest causes of evap coils prematurely leaking. Sorry wish i could be more help.
Sep 17, 2009 | Intertherm P3RA-042K Air Conditioner
Taking apart a transmission
Remove & replace the trans is probably about 4 to 5 hours alone.
to overhaul, it's easily 3.5 hours.
Ford publishes Service Labor Time Standards and other companies do inflate them some for their manuals because Ford techs only work on Fords and know all the ins and outs to repair them. Outside garages work on all models and never get that familiar with just one model. They do charge less/hour than a dealership so it kind of washes out.
Aug 22, 2008 | 2002 Mercury Mountaineer
Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
Feb 20, 2008 | Powerware 9120 UPS System
HP 500VA UPS System Logo
27 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
