Question about GE GSH25JFR Side by Side Refrigerator
Side by side cooling problems
My side by side ge freezes at the bottom only and in the fridge, seems like a circulation prob?
    Director Badge:
    Uploaded 100 video answers.
  • GE Master
  • 489 Answers
replacing evaporator motor and mother board
Posted on Oct 16, 2014
    Genius:
  • 1,073 Answers
Is the fan running in the freezer, if not then the freezer fan motor could be bad, if it is ge allso sugest to replace the main contro board all so at the same time
Posted on Apr 10, 2008
6ya staff
SOURCE:
GE Monogram ZIRS36NMHRH coils at bottom of fridge freeze up on one side and the temp is not as cool as it should be. This happened 2 or 3 years ago and we replaced the evaporator, but here we are again. ...
Hi Michelle, most likely your unit is having a problem defrosting. I recommend getting a professional on this one. The defrost heater, thermostat and timer need to be checked to determine what is malfunctioning.
Nov 21, 2013 | GE Monogram Side by Side Refrigerator
My ge profile bottom freezer refregrator is freezing everythin
is it freezing everything in the fridge as well? if so i had the same problem with my side by side fridge a while back. the appliance repair man told me to vaccuum the fridge underneath and all the other parts behind i did and it seemed to work well after that. also have you checked your temp controlls in the fridge.
Jan 02, 2013 | GE Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 28, 2012 | GE Refrigerators
I have a ge refridgerator gss25k side by side. thefridge/freezer are not cooling. the bottom of the fridge freezes and the top is warm.
There is an air duct that connects the fridge to the freezer. A fan circulates air to cool the refrigerator.
The inside fan has stopped working or is blocked by ice.
Defrost the freezer. If the fridge starts to work properly then you have an auto defrost problem. If the fridge still does not work then there is a faulty fan.
A technician can help you there
Apr 03, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
GE model 25 - 6 years old - Top part of fridge and freezer not cooling. compressor seems to be working fine. Bottom part of freezer is very cold and bottom part of fridge is freezing everything. Appears to...
It sounds like the damper assembly might have failed or be stuck open. The damper is mounted in the left side upper rear corner of the refrigerator section. The damper controls the amount of cold air that comes into the refrigerator section from the freezer.
If you want to repair the refrigerator yourself you should disconnect the power to the refrigerator and remove the 2 screws holding the damper cover to the center wall. Sometimes you can spray the damper with WD40 and free it up.
Jan 30, 2011 | GE Profile PSW26P Stainless Steel Side by...
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
@15 yr old GE top freezer fridge. Top freezer
heatman101
Mar 30, 2010 | GE GTS22KBP Top Freezer Refrigerator
Freezer not freezing & fridge warm at top and freezing at bottom.
Check and see if you have a fan that is not working. A condenser fan might just be your problem. The air is not circulating right. If this isn't the solution try turning the frig off for a couple of hours to see if it will correct the problem. BB
Dec 15, 2009 | GE GSS22SGPSS Side by Side Refrigerator
Item in fridge freeze at the bottom, but barely cool at the top
has the cold air circ fan stopped or jammed? this will allow the cold air to drop to the bottom and not circulate.
Mar 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridge cycling cool to warm
yes, you should not have a gap. It is allowing warm air to circulate in ref.
Jan 17, 2008 | GE GSS20IEM Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
204 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
