Question about HP Officejet 5610 All-In-One InkJet Printer
Fax who can we see a sended fax on HP Officejet 5600 series fax
  • ggrady Apr 04, 2008
    I have a HP officejet 5610 all in one ink jet printer and i tryed to fax and i don't know how and now it doesnt print. help. i turned it off for 15 minutes and still not working. can you help me. thanks
u can press set up go to advanced fax set or basic fax set up and then go to fax logg > press ok on that .
u can get the details of the last 10 or 15 faxes.
Posted on Jun 05, 2008
HP OfficeJet 5610xi Solution Center Download?
Please go to and put officejet 5600 in the search bar and you will find the software program for it. If you can't find it there contact me and I will get it for you. 713-204-9111 or
Please leave me good feedback if this helped you.
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Two sided copies
see your hp all in one help section should be installed as part of your printer software
Apr 09, 2009 | HP Officejet 5610 All-In-One InkJet...
Fax problems with hp 5600
I have fax pluged into phone line and every time I try to send it states fax failed. How do I correct
Jan 28, 2009 | HP Officejet 5610 All-In-One InkJet...
My printer screen says no connection
disconnected all cables and connected back.
Jan 11, 2009 | HP Officejet 5610 All-In-One InkJet...
I have just recently purchased a HP Officejet 5600 All-in-One series and I need to know if it is compatible with my digital cable phone in order to be able to use the fax machine successfully. I contacted...
Hello rduliban,
HP Faxes that come with the All-in-One's are designed to work with analog lines to send and receive faxes. You may not be able to use the fax machine on a digital line (In some cases, they may work but unfortunately in most of the cases , they won't work).
In this case, there is nothing you need to consider about the T.30 as basically, all the available fax devices comply with the T.30 standards to communicate with each other.
good luck
Oct 20, 2008 | HP Office Equipment & Supplies
here are the things that i want you to follow to somehow resolve your issue.
1. On your computer, click on start then go to control panel
2. inside control panel open the PRINTERS and FAXES (XP) or PRINTER (VISTA).
3. make sure change the default printer icon to the HP Officejet 5600 series.
- right click HP Officejet 5600 series and choose "set as default printer"
4. then try printing,
note: the reason why you encounter that problem is because the default printer icon is the "HP officejet 5600 series fax".
best regards
Apr 04, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
96 people viewed this question
Ben Johnson
