Question about Canon PowerShot A710 IS Digital Camera
Re lens damage
Hi i bashed theside of the lens and now i get some blured images and lens error on zoom.is it expensive to replace lens and is it straight forward?
    Genius:
  • 1,691 Answers
When replacing a lens, there is some optical and electronic calibration required.
In your situation, if there is any part of the camera case that was knocked out of shape or slightly bent, then for sure the repair will be too expensive.
A bend or change of a few thousandths of an inch of the case cannot be seen by eye. But with the precision and magnification of the lens, any slight misalignmenet would be visable in the photos.
You should call Canon just to know the cost of servicing the camera. I am sure it will be more than 50% of the cost of a new one.
Jerry G.
Posted on May 29, 2008
6ya staff
SOURCE:
System error focus
you hve probably damaged the lens unit. impact while the unit was extended? the auto power off will retract the lens thus damaging the little plastic gears in the lens unit. you may need to replace the lens unit
Dec 18, 2013 | Panasonic Lumix Dmc-fh1 12 1 Mp Digital...
My new panasonic lumixDMC-ZS8 14.1MP Digital camera gives me system error (zoom) when I turn it on.the lens will not open?
The systems control board has detected a fault wth the lens, over time dirt and grime collect in the len causing havoc, the other concern is the gears have jammed or got damaged, either way it is a major dis-assembly and it will be expensive.
Mar 20, 2012 | Panasonic Cameras
E:61:10
The error e:61:10 signifies a stuck internal lens. Shut it off and tapping it on the side might work. If not you could have it repaired. In that case you may as well buy a new camera. Sorry.
Jan 07, 2012 | Sony Handycam DCR-SR100 Camcorder
When power on blured screen apear and blured image
1. Try cleaning the lens with a soft dry cloth. Do NOT blow on the lens first. 2. You could be experiencing camera shake - if you are in shutter mode and if your shutter speed is too slow for the light available you get a blurred image.
Dec 31, 2010 | Olympus Stylus 850SW Digital Camera
Keeps on saying zoom error
Hi, you have problem in lens unit maybe the lens gear are damage or misalligned. If you can open your camera and check the lens unit if they need to be replace the damage parts, clean the gear becuase of sand or dust and adjustment only.
if you can't do this bring to service center and request for estimate charge first before proceed to repair.
good luck and thank you my friend
Jul 17, 2010 | Fuji Cameras
When i turn on my panasonic lumix dmc fz28 it shows system error
HI there the camera lens guide pin is damages and thats why not zoom the image properly . You got the system error message. So you need to replaced or repair the lens guide pin. Thanks.
Apr 01, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Blured zoom shots due to low light
Hi Charles A/f works on contrast it 500mm f6.9 even at 1600 iso it willl make no diffrerents if it to dark it will not lock on
Jan 03, 2009 | Canon Rebel XT / EOS 350D Digital Camera
The left side of my pictures are blured.
If it's been like that since Day 1, I'd guess either an improperly assembled lens, or a misaligned CCD in the body. Hopefully it's a warranty fix. If it has recently started, it may be due to impact to lens or body. Fingers crossed for the warranty situation.
May 20, 2008 | Nikon COOLPIX S200 Digital Camera
Samsung digimax 420 zoom error
The Zoom error could be motor failure or a connector come loose. you could try the Samsung Technical Help Team Byt I suspect it is time for repair or replacement[ depending on age of the device]
May 31, 2007 | Samsung Digimax 420 Digital Camera
Canon PowerShot A710 IS Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
