Question about Refrigerators
Fridge running warm
I have a about 20 year old Maytag RTS17 that is as not cold anymore. THe lower chamber only gets to 40 degres and the upper freezer to 32.Is it repairable?
  • 1 more comment
  • rmolson Apr 02, 2008
    the back of the unit is 4 inches from the wall the frdige is set at 6
    The freezer at F I ljst recently vacuumed the fan housing. there are no exposed coils just the sealed compressor
    I did pullout the drip pan and there was some dust, vacummed it it out and now will wait and see thank you
  • robert samples May 11, 2010
    are there coils in the back and do you have them pushed against the wall and what setting is your thermostat at
    President:
  • 1,314 Answers
Well the coils are underneath then but they are there get a flashlight and look under the fridge bet they are covered with dust you in the usa
Posted on Apr 02, 2008
  • robert samples Apr 02, 2008
    on the coils you can get a coil cleaning brush at lowes but that just might fix yor problem
SOURCE:
My 20 year old Maytag fridge has stopped cooling properly. It will cool the freezer to about -4 then warm to about +4 and continue to do this. What might the problem be? i
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Maytag Refrigerators
No ice setting in upper chamber of freezer lower chamber working
Cold air goes down and especially hangs right around the area where the heat is removed (cold is generated). A fan exists which continually moves the air around in the chamber so that there will be no warm spots. Opening the door allows a spring loaded switch to move toward the opening which shuts the air circulating fan off so that cold air will not be blown out of the fridge or freezer while the door is open.
Depress the switch. Does it click? Some switches do not make an audible click. Can you hear the fan turn on? The switch is in the door jamb. The fan is behind the vent holes in the compartment.
:o).
Jun 04, 2011 | Daewoo Refrigerators
I have a Performa side by side 7 years old, had a repairman out because it started running constantly...Dx was there is a freon leak. Isn't this uncommon for a fridge that is not THAT old?
It happens alot in my 18+ years i have seen them leak 1 day later to 30 or 40 years later.If it was running and not stoping and freezer and fridge warm or hot it may be a leak if it runs alot and freezer is cold and fridge warm then it is not a freon leak.
May 18, 2010 | Refrigerators
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
Maytag side by side not getting cold enough
look in the back should have a fan in the bottom probably very dusty if it is it cant cool fridge clean it and it should work unplug it to clean
Jun 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridge and freezer not cold
It happenedn to my performa fridge just yesterday. It was bought in 2005. Now there is humming and clicking sound from the lower back side once in a while and the fridge is not cold. the compressor is hot/warm and it seems to be where the noise is coming from.
Jun 21, 2008 | Maytag Performa PAV2200
Upper Fridge Too Warm
We had a warm fridge and super cold freezer.....we unplugged for about 20 minutes and the fridge started to cool down again.... but only for a few days then back to warm.
We ended up unplugging and "defrosting" the whole unit for 24+ hours ....Now it works perfectly again.
I think it happens when one or both of the doors is not shut or sealed all the way and engine works too hard and "freezes" up the fans or some other part of the system.......I am just happy I did not have to buy a new fridge.
Mar 30, 2008 | Maytag MB2262H Stainless Steel Bottom...
Maytag fridge s-by-s freezes alot of the stuff at the back and lower vege drawer
Actually this seems about right. The air flow in the fridge is usually from the back top of the fridge. That will be the cold spot then the air sinks down to the bottom and then recycles back into the freezer comp. to get cold again. Door shelf is usually warmer than the rest. As with most units, it takes some understanding of the air circulation pattern in order to find the sweet spots for dairy products and meat, veggies, etc. Check to see if there are slider adjustments on the drawers for temp or humidity, etc. Also make sure there are not parts missing from the inside of the fridge. Sometime a part that appears to only be a small plastic item gets broken over time and never replaced when it could actually be very important to air circulation. I recommend getting a small floating aquarium thermometer and setting it in a glass of water in order to get the "true" temp. of the products not just the air temp of the fridge. Put the glass in different locations over a weeks period to record what the temps are like in different areas of the fridge so you can make a "map" of the cold spots, etc. Leave the thermometer in for about 12 hours before you record the temps for that location. I think you will find the answers you need in order to place your food more effieciently in the fridge. As for summer days, the unit will have to work harder in warm weather to cool than it does in the winter months of course but there is always a concern that you are not cooling 100%. The way to check that is to let the unit run for several hours (turn the temps down so it runs for at least an hour solid) then you would have to pull the whole interior rear freezer panel off the back to view the cooling coils and make sure they are fully frosted across the whole coil surface. If they are iced up only in a few inches of coils then you likely have leaked out the liquid refrigerant over the years and there's not enough to cool a full 100% of its capacity. And your complaints are the same with even brand new models... it's about 60% of our service calls (not cooling properly or freezing food).
Jan 28, 2007 | Maytag MSD2756GES Side by Side...
Refrigerator is not cold but freezer is still operating.
Couple things, both doing with air flow. If the fan in the lower freezer isn't working there will be no cold air moved into the upper fridge. If the defrost cycle happens to be dead then the coils down there will freeze solid and there can be no air flow over them to cool the upper area. You'll have to pull the lower drawer out and take off the interior rear panel to check these things. Hopefully it's just that the fan motor went out. It's real easy to change. Let me know what you find, if the coil is all iced up solid then there's more things you need to look into.
Jan 08, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
