Back to:
Tags:
Tyan MBD SSIE DUAL XEON 5000 5100 1333FSB GETH SAS Motherboard
Having problems trying to get a Tyan i5000xt MB to...
posted by Orinn on Apr 02, 2008
Motherboard: Tyan i5000xt S2696
Video Card: BFG GeForce 8800 gtx
I have everything mounted in the case and everything is recieving power (fans all work). I try to boot it up so I can access the CMOS but I can't because I am not getting a display. I am not recieving anything on the monitor, just a no signal display. I tried different vid cards and still the same. I don't get any warning beeps from the board either. I replaced the board with a new one but still getting the same issue. I don't have anytrhing installed because I haven't even gotten to the install process yet.
Comment by Orinn, posted on Apr 02, 2008
Still no display, no beeps, no wornings nothing. Tried all that. There is a jumper 17 (JP17) that is unknown from the book and I'm curious as to what it is for but as still stated, still no display. The monitor knows it is connecting to the card because it does the cable not connected (if not connected) but then switched back to no signal.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
Geno69
Rank:Wiz Wiz
Rating: 84%, 314 votes
  1. If the MB has jumpers, you must make sure they match you CPU.
  2. Make sure you have the right memory modules and that they are installed correctly.
  3. Unplug all drive cables from the mother board (HD, CD, DVD, Etc) and then try to boot. If you see video, plug them back in one at a time.
Hope that helps...
Geno
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Having problems trying to get a Tyan i5000xt MB to allow the vid card to come up with a display:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Motherboards
I need electrical conection drawing for D845WN Thanks for...
Motherboards
i still have this problem on unknown devices - Intel(R)...
Motherboards
hey i need help with my problem that im haveing with my...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
