I have a panassonic 50" plazma tv, when using it as a pc monitor the screen goes blank how do i stop this, many thanks, patsy
  • 58 Answers
Does the screen go blank after the computer has been sitting unused for a while or is it immediately blank and does not show a picture. If it goes blank after a while, look in your power settings under control panel on your computer and set the monitor cut off to NEVER, also check your screen saver settings. If it does not show a picture at all check the user manual of your TV to see the supported computer resolutions and then check under display settings on your computer to see if the resolution that you are using is compatible. Hope this helps.
Posted on Apr 02, 2008
SOURCE:
Losing TV picture, screen goes blank,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Televison & Video
The TV works but the screen is completely blank. What do I do to fix this?
- Flickering screen
- Dim screen
- Slow start
Feb 11, 2014 | Samsung PN50A400 50 in. HDTV Plasma TV
Hdmi 1 not working panasonic 50 plazma
need the model number to assist but it sounds like a main board issue if you have one of the panasonic plasma models that have the inputs all on the main board. You can get main boards for most models at www.tvrepairworld.com
Mar 22, 2013 | Panasonic 50 in. Plasma TV
LG 50 Plazma screen is dark pink sometimes goes to normal
Might be to some loose interconnection cables. Seek tech support.
Jun 09, 2012 | LG 50PS60 50 in. Plasma HDTV
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
When I turn on my computer it goes through the windows process and then the screen goes blank and says in a box " no input controls ". Help
It is telling yopu it is not getting the video signal from PC or it may have problem. You should try it with another PC to find out if it is PC or Monitor problem, cables are good?.
Post back what you find.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 21, 2011 | Acer TFT screen 17" AL1715MS Flat Panel...
When i shut my laptop the tv i use as my monitor goes blank.
Right click the power icon in the system tray (should look like a little plug with a lightning bolt on it.)  Click on "adjust power properties."  Click on the "advanced" tab, then where it says, "When I close the lid of my portable computer," select "Do Nothing."
Jan 25, 2009 | HP GX612AA Pavilion Media Center M8330F...
Gateway MT3707 Laptop external monitor hookup
i have been playing music videos. i use the fn f4 button to switch the screen. so when i switch i can see the videos on my laptop and on my plazma both. but after awhile i lose the signal and the video only appears on my laptop only. when i hit the fn f4 i can't get it on both screens. it works fine for a while then on the plazma it goes blank.
Oct 19, 2008 | Gateway MT3705 Notebook
Connecting an LG TV to my PC
dear sir
i think u have screen resolution pro.
change your system resolution to 800x600 .reso.then restart .
i think your problem is solved
Mar 16, 2008 | Computers & Internet
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Ekse
