FixYa.com
Tags:
Garmin StreetPilot c340 GPS Receiver
Garmin C340 GPS - Will Not Power On
posted by Skipper Den on Apr 02, 2008
I bouhgt a refurbished Garmin C340 GPS system. It's 2 days old and will not power on. It would not power on out fo the box. When I snapped the C340 into its cradle whioch was plugged inot my car's cigarrette lighter socket it worked immediately. And it worked fairly well - it did take about 10 minutes to locate satellites. But it worked slick. I used it for about 30 minutes and stopped at a store. I was in the store for about 50 minutes. When I came out the C340 would not power up. I took off the face plate and hit the reset button, it still will not power up. I have connected it to my PC, but sicne it won't power on the Windows XP software doesn't know what the device is and stops the loading of my Garmin GPS driver diskette. So the unit appears dead. Is there anything I can do or should I just return it and buy a Magellan?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 05, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I just bought (and received yesterday) a refurbished unit through Amazon.com. I had the same power problem. Finally I figured out that I could charge the battery by hooking the unit up to my computer with the USB cable. The battery fully charged after about three hours. The unit makes a loud sound when the battery is full.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these GPS Devices problems?
Garmin c340
When I turn on my garmin i just... Answer This...
Garmin c340
My GPS unit just stop... Answer This...
screen went dark fuse ok tried...
I was driving along and the... Answer This...
GPS does not tell you the...
I have a Garmin StreetPilot... Answer This...
certified refurbished garmin...
problem with poor reception all... Answer This...
Repair Service
Find GPS Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
