FixYa.com
Tags:
Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher (by 2 users)
posted by annemarie08 on Apr 02, 2008
water filling in dishwasher for no reason not runnig?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by bill25, posted on Apr 07, 2008
My  bosh  dishwasher model  SHU33060C  The motor is running  But it doesn't  Take in water  90% of the time, the unit is aprox 3.5 years old,
any help,?  DDedalos@aol.com,Thank you,
Solution #1
posted on Apr 02, 2008
Not Rated (0)
zeusfaber
Rank:Guru Guru
Rating: 85%, 219 votes
Good news is, this is unlikely to be expensive.
Need to sort out where it's coming from first.
Find a stopvalve you can use to shut off the water supply to the machine - there's probably one where the dishwasher is connected to the domestic plumbing. If turning this off stops the water coming in, you probably need a new inlet valve. The ones on dishwashers are generally pretty cheap to replace.
If shutting the water off doesn't stop the inflow, then the only place it can be coming from is siphoning back in from the drain. There's supposed to be either an air gap or an anti-siphon valve where the dishwasher's drain hose goes into the domestic drain. If this gets blocked/stuck, then it can cause dirty water to siphon back into the machine. Check and clear as necessary, then run the machine through on the hottest, longest cycle it's got (in the expectation that not all the water that was sucked in from the drain necessarily started out in the dishwasher).
A.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dishwashers problems?
powerpoint idw8
Displaying E2 can you tell me... Answer This...
Bosh dishwasher shu3322uc/22
(Bosch shu3322uc/12)Dishwasher... Answer This...
No water will come in
I can turn the dishwasher on... Answer This...
I can't push any buttons
The only button that will... Answer This...
Bosch Dishwasher
My 8 year old Bosch is not... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
