FixYa.com
Tags:
Printers
Generic problem for all Printers
Set up to receive fax (by 10 users)
posted by robinmetzger on Apr 02, 2008
set up to receive fax
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
9 Other Users Have The Same Problem
Comment by anilashastri, posted on Aug 28, 2008
I am having problems in sending and receiving faxes.
Comment by elkay5, posted on Aug 04, 2008
I have a Canon Pixma MP780 and it is unable to receive faxes. My phone line has Verizon Voice mail and that might be a problem. I have the fax set on manual receive but when I pick up the phone and there is a fax tone and I push the Start button nothing happens. Am I using the wrong setting for receiving faxes?
Elkay
Comment by arbor, posted on Jul 21, 2008
cannot receive fax
Comment by Guest, posted on May 21, 2008
can not receive incoming fax
Comment by eveportis, posted on May 03, 2008
I have the officejet v40 all in one. I have not use the fax in some time. How do I set up to receive a fax. I cannot get the fax phone signal. What do I need to do to turn my fax on to receive incoming faxes?
I have tried to set up iwith the options but to no avail, Please help.
Best Solution
posted on Apr 28, 2008
FixYa! (100)
MURDAN
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 30, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Problem sending and receiving Faxes using HP C6180 and VOIP. Could someone help?
Thank you.
This Problem Also Relates To: HP Officejet 5610 All-In-One InkJet Printer HP OfficeJet 6210 All-In-One InkJet Printer HP Photosmart C5180 All-In-One InkJet Printer HP Photosmart 3310 Printer HP DeskJet 1280 InkJet Printer HP Officejet J5780 All-In-One InkJet Printer HP LaserJet 2420 Printer
Can you Help with these Printers problems?
Printers
Code F2-04 displays on our
Code F2-04 displays on our... Answer This...
Canon PIXMA MP210 Photo All-In-One Printer
computer been fixed do not have...
i dont know how to set my canon... Answer This...
Printers
what does error 6000 means
what does error 6000 means on a... Answer This...
Printers
Printing problem
Hi, I have a problem when... Answer This...
Printers
the printer wont install
the printer wont install Answer This...
9 Other Users Have The Same Problem - Continued
Comment by fixfax, posted on Apr 29, 2008
the only way to receive fax is to push the startfax-button when an incoming fax is ringing. The menysetting is set to automatic receive and answer after 2 signals.
Comment by norberto44, posted on Apr 28, 2008
can not fax or receive faxes
Comment by Simon Wrench, posted on Apr 27, 2008
Can send faxes but not receive them. Have a BT landline & broadband phone.
Comment by ozoil, posted on Apr 15, 2008
I hear the fax ringing then I have to push hook, black start and then #2 for receive----can't I have it automatically set to get my faxes? I am missing them if I am away from my desk.
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
