At first start up runs rough give it gas it wants to die once its warmed up runs fine ,new cleaner,fuel inj.,filter,befor i changed all that it idled at 750 now it"s 1200 rmp. help
it may be idle control sensor or a bad mas air flow sensor--maf sensor in otherwords. or could be engine misfire at cold temp. start. only time when cold? or does run better when warm? try warming engine to operating temperature before driving,if problem removes it's self after warm up,up grade gas to 93 octane for 1 tank full. then see if problem goes away. it's cold where you are right? if so the fuel needs to be at least midgrade 89 octane fuel because 87 octane fuel will not start your honda correctly at cold temps. in cold weather 93 or super gas octane will start ,no problem,low octane fuel sometimes gels, or freezes at low temps. if in warm climate, change the fuel filter, add fuel injector cleaner to your fuel tank[preferablly lucas fuel treatment] this will lube your fuel injectors and give better fuel mileage. thank you for choosing fixya.com
1988 ranger 2.9 runs great cold then after a few minutes when warmed up hesitates with intermittent black smoke from the tail pipe until i hit the the throttle then clears and will repeat this behavior...
Hi! I had the same problem with my 88 2.8 Ltr. Had dirty fuel Injectors. Put in fuel Inj. cleaner in gas tank, after a couple of days, runs like a dream,no more problems. Give it a try. Take care,Leo B. [email protected]
fuel regulator
