Question about White Sewing 915
Broken spool spin
How can i obtain a new spool spin for my white 915 sewing machine
  • 106 Answers
Www.sewusa.com
You should find what you need, email them if your part is not listed
Posted on Apr 02, 2008
SOURCE:
What size bobbin for White 915?
On sewing machines with the removable metal bobbin case the bobbin size will be a class 15, very common and inexpensive.
Dec 10, 2015 | White Sewing 915
How do I fix a White sewing machine #445 that keeps breaking the upper thread
Check the thread spool to make certain the thread is not getting snagged on the edge of the spool (or the little slit where you pull out the thread from the spool); then check your tension paths and settings (I once found broken, tangled metallic thread in the needle 'uptake' loop that was snagging the thread and making it break).
Canned air is excellent for cleaning out older models as well as the new electronic machines.
Feb 03, 2015 | White Sewing Sewing Machines
How to remove broken spool pin part in my Singer 6038 to install new one?
Take the machine into a repair shop. You won't have all the tools or the parts to make the repair properly.
Oct 03, 2014 | Singer 6038 Mechanical Sewing Machine
Sewing machine design
It sounds like the spool cap is broken or defective. It should fit snugly on the spool pin. If it is constantly falling off, then try finding a replacement. The horizontal spool pin design helps the machine pull the thread off the spool because the thread spool does not need to spin. The added pressure of spinning a thread spool contributes to tension issues (especially if you are using large thread spools that are so common now days).
On new machines, frequently the thread cutter is on the back of the presser foot lifter.
The thread guide above the needle is usually threaded from the left side because the thread tends to be pulled toward the right.
Unfortunately, what you are experiencing are pretty much common functions with most newer sewing machines, so even changing machines may not result in any greater degree of satisfaction.
Mar 31, 2017 | Singer Sewing Machines
How to replace spool pin on model 5160 singer sewing machine
Drill and tap out the broken bit. Put new one in.
Aug 30, 2012 | Singer Sewing Machines
Spool is bouncing on spool pin
Get a stand alone spool holder, sometimes the spool pins arent high enough to support the thread or you can try a thread sock
Jul 16, 2009 | White Sewing Mighty Mender WW100...
Broken horizontal spool spin Brother Xl 2027
hi i have the same machine listed on ebay works great just the foot need to be replaced hope that helps
Mar 31, 2008 | Kenmore 19001
White Sewing 915 Logo
105 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
