Question about Frigidaire FRS-26DR7D Side by Side Refrigerator
Frigidaire Side by Side Icemaker
Ice is getting stuck on the top of the icemaker. When the paddles cycle around, they jam ice into the icemaker and therfore stop the ice making process. Any solutions?
  • 2 more comments
  • Anonymous May 06, 2008
    I have the same problem with my Kenmore Elite 10652603100, I understand that there is a "upgrade kit" consisting of a new ejector and stripper but I havn't found the part number for it yet. Maybe someone could help out on this if they know the number and source.
  • Anonymous Jul 17, 2008
    Our ice tray jams up off and on, but this week it's been constant. It used to also never STOP making ice. Currently the trays are full, but won't spit out ice, so this is a new one. We've had various issues since it was new, but nothing too serious. Now, almost 4 years later, it's been giving us trouble for a week straight... and it's 91 degrees out!
  • rreiner3 Aug 03, 2008
    Same problem exactly!
  • Anonymous Aug 09, 2008
    Ice is getting stuck on the top of the icemaker. When the paddles cycle around, they jam ice into the icemaker and therfore stop the ice making process. LJ
  • Frigidaire Master
  • 19,396 Answers
The icemaker evaporator system that releases the cubes is faulty , and must be replaced.
Posted on May 22, 2009
Icemaker is not making ice and the refrigerator is not getting cold
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Feb 28, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice maker has 1 piece of ice that always gets jammed and will not get ejected
on the underside of the icemaker there is a metal heating element make sure it is flush to the bottom all the way around. If the element does not heat the bottom ice will not pop out.
Aug 06, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Icemaker is making ice but it will not drop into container
Ice maker has built in heater to thraw ice alittle so the finger scooper lifts up ice and out. Be sure the ice cubes are not stuck in between fingers cause that will jam it. if you dont see any jam then replace ice maker
Mar 28, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Jenn-Air JCD2389GE side-by-side refrigerator ice maker. Numerous problems since purchased in 2002. The latest is flapper door opening and closing repeatedly at two second intervals and water pouring out...
Getting to the more serious water leak problem, it will be likely caused by one of two problems. the first, more common problem, is the solenoid for the icemaker valve is likely stuck open. sometimes particles in the water will literally prevent the solenoid from closing, like jamming a stone between a piston inside an engine cylinder, causing your water to overfill your icemaker, fill up the bucket, and pour through the flapping door that you also have problems with. the second possible problem, is your icemaker itself has stopped, or to be more precise, the motor has ceased up, and it happened to stop at the point in the icemaker cycle when it calls for water. You can check to see if the valve is the problem, by removing the icemaker entirely from the freezer, its held on by 3 screws, or possibly one screw and two metal or plastic clips, also unplug the icemaker from where it connects electrically. Assuming you have the water to fridge turned off presently, turn the water back on, and see if water comes through the fill tube. If it does, the valve is your problem, I suggest replacing both the primary and secondary valves. 12001892, 61005626 are the two part numbers.
If water is not coming out of the fill tube, take a look at your icemaker. Look at the icemaker as it was when mounted, and inspect the center ejector shaft, it runs down the middle top of the icemaker, and has 11 fingers on it, it is what rotates around to eject cubes. Is it in the "home" position, i .e. the position it sits while water freezes. The home position, when looking at the ice maker in its normal orientation, is when the ejector shaft teeth are pointing at 2:00. If the teeth are in any other position, either the ice maker was disconnected during its cycle, or the motor has stopped. To be certain, with the water remaining off, reconnect the ice maker, pour about 8 oz of water in the ice maker, if after 24 hours there is no ice ejected, then you have a bad ice maker. part # D7824706Q
In regards to your flapper door problem. since the path of water went through the door dispenser,its possible you may need to replace electric panel for dispenser. An inconvenient fix is to unplug the connection for the dispenser, located either at the top, under hinge cover, or at the bottom, after removing toe plate.
I fix refrigerators
my website: www.FixMyFridge.net
Mar 08, 2010 | Jenn-Air JCD2389G Side by Side...
Ice maker stopped working. Red light is blinking.
  • That means no flow of water to icemaker. So check the solenoid valve paddle is stuck/jammed due to a fault in the Valve; replace valve.
  • accumulation of frost in the water supply tube &/or blockage
  • defrost button stuck
push the door close button with your thumb, insert the ice tray, any water flowing into the icemaker??----------- observe the position of the paddle & don't forget to check the defrost button is not engaged.......sodeep
Oct 26, 2009 | KitchenAid (KSRD22FKST) Side by Side...
My icemaker was working at one time but now is not working .. I can feel the ice inside the icemaker unit.
Often these icemakers just get jammed because the ice cubes stick together. Carefully dislodge all of the existing ice and it should be ok
Jul 31, 2009 | Frigidaire FRT17G4B Top Freezer...
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
Water but no ice. ice in tray
If you have a "paddle" switch just below the icemaker make sure there is tension on it, i.e. the tension spring might be loose. Make sure the tension spring end is inserted into a tiny hole. Mine wasn't, I did it and ice maker works fine now.
Jul 17, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Frigidaire FRS26ZRGW8 ice maker stopped working
on your icemaker you can tell if its a internal problem or a water valve ,,,,, 1st feel inside for any ice ,,, if ice is in icemaker the valve is working ,,, pull fingers on icemaker to get it started and watch it, if it makes its cycle and fills again the the icemaker itself is bad ,,, contact me and i will see if i can help with part or parts / larry
Dec 08, 2008 | Frigidaire FRS26R4A Side by Side...
FrigidAire Side By Side Slow IceMaker
there is no way to speed up the ice production, factory set only way to produse mor os depending on age of refig might have an "extra ice" button on display. even thats atemporary fix and probly speed up by 20--30 min
Jan 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
431 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
