Question about Samsung LN-S4051D 40 in. LCD Television
Power Issue I just bought my 40 inch Samsung the day before Superbowl. Lately it takes up to ten minutes for the tv itself to power up. Has anyone had this issue and is there a possible fix that I can try myself? Thanks for the help!
  • 58 Answers
This sounds like a power supply issue and since your tv is under warranty it should be easy for a warranty service center to repair. However I don't belive that there is any thing that you can do to repair it. Power supplies can be dangerous and it would also void your warranty. 1-800-sam-sung will be able to tell you the nearest service center or you could check their website with their servicer locator tab. Hope this helps.
Posted on Apr 02, 2008
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Tv keeps knocking itself off and comes back on indescrimently samsung 42 inch lcd
Hello, Good day.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem.....
May 21, 2011 | Samsung LN40B500 40 40" HDTV LCD TV
I have a Samsung LNT 4069 40 inch TV. I have had it for about two years but lately when we turn it on it does not come on as usual but goes through several clicking cycles and sometimes takes up to 2...
Yes,
This is a problem with some capacitors on the power supply board, they have defective formula. The ESR levels are high and they can't hold their operating voltage. If you have an extended warranty by all means take it back exchange it for a new TV.
http://tvtechwork.webs.com/
Nov 17, 2010 | Samsung LNT4069F TV
I have a Samsung LNS3251D 32-Inch LCD HDTV , that after two years of use is going Off/On every ten seconds after the initial turn On. I understand from reading this forum that the Samsung 40 inch LCD has a...
In almost all cases where the set is taking a long time to turn on and then turning off it will be the Power Supply board that will have bulging capacitors, usually three to five. Look on the upper right side of the Power Supply and look for any blown caps. You can replace these caps and you will be fine. Now the other cause can be the Power Switch is shorting out. You can disconnect the the Power Switch but not the IR sensor and then turn ON the set with your TV remote and see if this stops the problem. If you are not skilled in component level repair on the Power Supply board then buy a new Power Supply board and install it.
Apr 15, 2010 | Samsung LN-S3251D 32 in. LCD HDTV
When i turn my samsung 40 inch tv on it makes a tick tock noise and takes a very long time to come on
To all who are having power supply issues: Samsung is now acknowledging a problem with faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem
Jan 15, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung dlp HL56A65 turns off and on by itself
It looks power board problem.
You need to get service from Samsung.
Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Dec 31, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung TXR3079WHX TV shuts itself off!!!
transistor bad shorted tr-power j6920 org. part#0502-001230 located near flyback.don`t no location #
Aug 24, 2007 | Samsung TXG2548 TV
Samsung LN-S4051D 40 in. LCD Television Logo
73 people viewed this question
Henry  Thomas
Henry Thomas
