Question about Tomtom One XL GPS Receiver
Disassemble tomtom xl
How do i disassemble my tomtom xl. I have removed the 4 screws but i cannot get it apart.
  • 1 more comment
  • ostryjak Mar 29, 2009
    I did need to use a small screwdriver - my nails are too soft and plastic just doesn't do it. I did not mark the plastic (and would it really matter if you did have a dink in it ? I don't think so) and once I had started the case opening I worked my way around the edge using the screwdriver popping the 2 pieces apart until they eased apart like a clamshell opening.
  • Anonymous Apr 27, 2009
    The back was already off as smartinks states he has removed 4 screws ( there are 4 more to remove) 8 in all. The cable loom ease the ends of the larger (to screen) plug fixture back at each end then ease out cables. Remove smalle push in plugs.
    I need to also get my screen out to put in replacement and am not sure how to proceed, any tips appreciated
  • Grant Whiting Apr 27, 2009
    I have just replaced my tomtom one XL screen and all is working well. Please disregard my last posting .
    To remove the back. as you look at the back, on the top left is a catch (burried eyelet) underneath inside is a sprung loaded catch. use a small screwdriver or a piece of bent wire to pull until the corner opens, now work the opening around until the back opens, be careful of cables. Unplug the 2 plugs located at the side . unscrew 4 internal screws.
    To release the wires from the screen, ease up the plastic wedge from each end of the wires and ease out the wires. Its a small plastic lug just to the left and right of the wires, this is very fiddley to replace
    I would not recomend anyone with no electrical training to undertake this. The screen has to be popped out from the front. General advice touch as little as possible. Good luck
once you have taken the 4 screws apart, the back cover is attached to the front one with plastic latchs. To open them, the best is to use one nail or a thin piece of plastic. Do not use an screwdriver or any other metallic tool or the covers will be marked. Begin with one of the sides, then the other, then the top (or the botton, I don't remember). You should not apply a strong force, and be very careful when it is almost done, as the cables connecting the battery and speaker are very short and could e damaged if the case opens suddenly.
Be gente and you'll be done.
Hope this helps.
Posted on Apr 18, 2008
If my screen glass, that cover the LCD screen, is broken, do I need to buy a new LCD screen. That is, it attached as one unit? Or can one buy the glass separate from the LCD screen
Posted on Mar 25, 2010
My screen is broken is there any fix thanks steve
Posted on Mar 21, 2009
Hello, any pix and/or instructions on replacing TomTom GO 920
There are screws in the rear corners of the case, take these out, and the case will unclip, use a very thin blade or the like and slide it in between case halves, where the colors meet, and carefully twist it apart.
Feb 09, 2010 | Tomtom GO 920T GPS
TomTom 0ne
There are 4 screws:
1. Remove front bezel
2. unscrew 4 small screws (1 hole has anti tamper tape over)
3. remove "dome" rear of unit.
4. Remove 2 screws holding speaker in
5. Carefully remove all metal tape covering electronics
6. Remove 4 small screws securing PCB to unit
7. Remove 2 screws holding black plastic battery clip
8. Unplug small battery connector from PCB board.
9. remove battery and insert new one
Nov 09, 2007 | Tomtom ONE GPS Receiver
How do I remove the battery from TomTom One XL in order to replace it?
just remove the 4 screws on the back of the case and split the front and the back halves. becareful when removing the back cover as the battey and speaker are attached to the back cover and the wires are connected to the main board (front half)
the battery is attached to the back cover with two sided tape.
bill
Oct 31, 2009 | Tomtom One XL GPS Receiver
I broke off the power connector inside my Tomtom
I finally managed to pull back the rear cover by inserting a thin piece of metal at the top of the rear cover. It snapped off by pulling it backwards and then downwards. And I soldered the connector back on. I only had to solder the 4 feet of the small metal shield, the contacts are just pressing on the circuit board.
Mar 30, 2009 | Tomtom One XL GPS Receiver
Password issues with tom tom one xl
I got this similar password problem with Tomtom One XL. I just solve this problem step by step under the following ways.
1. Connect One XL to TomTom Home in your computer using USB cable and switch on ONE XL. (Click YES to connect each other)
2a. Click "Manage my ONE XL"
2b. Click "Items on device" tag.
3. Now you can see all of the data in your device and click "Applications".
4. Click inside the check box and click "Copy items to computer".
(This step is back up for just incase)
5. After Backing up your applications, then Click "Applications" check box and click "Remove from device".
6. After removing applications, unplug from computer and switch off ONE XL.
7. Connect ONE XL and computer again and switch on your ONE XL.
8. TOMTOM Home will search your applications in your device. Finally it will automatically download and installed the new applications. (There will be 4 times installation and the device will restart itself. At this step, you need to touch "Yes" on your device to connect the device and computer.)
9. After installation completed, your device looks like newly come out from the factory.
10. Set up Language, Time, and so on and ready to use.
Enjoy it
Austin Tan
Feb 10, 2009 | Tomtom One XL GPS Receiver
TomTom One repair
I, mine gps do not succeed to load with the cable with feeding in the car I am in montreal and I do not succeed to find an attendance center tom tom you can give to information thanks
Oct 10, 2008 | Tomtom ONE GPS Receiver
Cracked screen for Tomtom One XLS
Look for a screen on e-bay, I found one and found it simple to replace. MAKE sure the screen is the right one for your GPS
Jun 30, 2008 | Tomtom One XL GPS Receiver
Tom tom rider
I made a video on how it open your TomTom rider.
Feb 09, 2008 | Tomtom RIDER GPS Devices
Tomtom One XL GPS Receiver Logo
6,839 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
