Question about Nextar P7 GPS Receiver
GPS Nextar MN 2707
The touch screen of my unit went in. I found that the 4 litler screw which hold the screen from behind broke. They are tiny and have a piece of plastic. Now everytime that I touch the screen, it goes in. Can somebody tell me how to fix that or where can I get those screws. I've been looking for them but I havent find them.
Thank you
Best Regards
  • Anonymous Aug 12, 2008
    comment faire update pour gps nextar mn2707
Download upgrade and gps is now showing US maping instead of canadian maps how do i revese this.
Posted on May 13, 2008
SOURCE:
I have a Nextar Q4-01 GPS unit and the bracket that clips onto the back of the GPS unit has broken. The top small clip has broken and I would like to get a replacement piece. Are they available? What...
Here is a replacement mount. http://www.amazon.com/ChargerCity-Enhanced-ChargerCity%C2%AE-Manufacture-Replacement/dp/B003AALJHK/ref=sr_1_2?ie=UTF8&qid=1316990630&sr=8-2
Nextar i believe went out of business.
Sep 25, 2011 | Nextar Q4-01 Car GPS Receiver
My Nextar Q3 is a few years old and when I was trying to charge the battery while in my car the screen went blank and stopped giving directions. I tried restarting the unit but the screen went on briefly...
you need to open it and check the wires behind the power board sometimes those wires get loose from the solder weld the battery its ok if you have it connected to your car lighter, I had that happen to me so I opened it and found broken solder welds at the end of those wires, it is a very delicate work to get to it but I think that's what it is.
Sep 30, 2010 | Nextar Q3 GPS Receiver
Broke my nextar gps car charger. Do you sell them
No. FixYa supplies advice only and mostly without charge.
FixYa does not sell any tangible goods of any description.
I'd usually suggest a supplier for your Nextar charger but you have not said which country you're in.
Nov 15, 2009 | Nextar X3-08 Car GPS Receiver
Touch screen stop working
Omnitech GPS systems are very decent for me. I have 2.
There were several reports of GPS problems beginning on or about 11-14 June 2009. This is due to the GPS navigation messages rollover from 255 to 0. Some GPS systems fail to accommodate this behavior; Omnitech is one of them.
Staples did provide a firmware update a few days later. There are also other firmware updates available on the net. I personally successfully update the firmware and resolve the problem around June 15, 2009.
Otherwise, the problem should go away after 1-2 weeks.
thsquare
Jul 12, 2009 | Nextar Q3 GPS Receiver
GPS stuck up
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Jul 07, 2009 | Nextar X3-02 GPS Receiver
Nextar GPS will not get past loading stage
Nextar will not assist in helping "fix" anything. Their solution is for you to send in the unit and they pitch it, send you one off the assembly line. I was able to get this unit working again in just GPS mode (what it was intended for), so using this workaround, you will lose the ability to use it as a tiny digital photo frame, MP3 player, etc.
I take no responsibility if you try this and "brick" your unit (render it unusable except as a $100 paper weight). BACK UP!!
1) Download and install ActiveSync from the Micro$oft website.
2) Connect the M3-04 unit to your computer
3) Turn it on
4) Red bar should fill and the M3-04 will "hang" in that screen, BUT viola it still connects to ActiveSync
5) Using Explorer from ActiveSync, navigate to ResidentFlash
6) Copy autorun.inf to your PC Desktop, make backup by renaming it to autorun.bak
7) Open autorun.bak with Notepad
8) Change the line to read without the quotes: "\ResidentFlash\Netropa Intellinav\IntelliNav.exe"
9) Save As to your desktop autorun.inf
10) Copy back to your ResidentFlash directory on the M3-04
11) Disconnect from PC and hit the reset button on back....BOOYA! Your GPS is functioning again.
Mar 19, 2009 | Nextar M3 Car GPS Receiver
NEXTAR 14-bct KEEPS FREEZING UP.
I just opened up a Nextar 14-BCT GPS unit and found the inner side of the ribbon cable is cracked. This unit has the exact same freeze on load screen as you do, so try looking inside, you may need the LCD ribbon cable or both LCD and LCD ribbon cable for your unit to function normally again.
Feb 23, 2009 | Nextar I4-BC GPS Receiver
Help with gps
Hi, Here is how to reset your device..
1- Turn off unit. 2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
If this helps you plz rate this 'fixa', if you have other questions post a comment & I'll be happy to help. Thank you kindly.
Feb 14, 2009 | Nextar Q4-04 Car GPS Receiver
Product registration for my new Nextar GPS unit
I had the same issue with the website. If you live in the U.S. call 1-888-849-0846 and they will do it over the phone. You must have your Serial number to register it.
Nov 29, 2008 | Nextar X3-03 Car GPS Receiver
When I turn on my GPS a white screen over a blue screen comes up which never used to happen
tap right hand lower corner of screen to get it to continue loading. I then upgraded the firmware to the P7 and I no longer have any problems with the unit... and it runs faster.
Oct 17, 2007 | Nextar P7 GPS Receiver
Nextar P7 GPS Receiver Logo
285 people viewed this question
Top Nextar GPS Experts
Marvin
Marvin
Thomas F. Schneider
Are you a Nextar GPS Expert? Answer questions, earn points and help others
