Question about Sony DAV-SC5 System
Speakers Can the 4 speakers be wall-mounted? If so, what brackets do I need? Also, I cannot play the subwoofer without having considerable vibration, so I have had to turn the bass off.
  • 682 Answers
In normal setup no wall-mount speaker- you must put subwoofer in the floor and vibration is normal for low frequencey of subwoofer.
Posted on Apr 04, 2008
How much airspace does Pyle PLBW154 1500W 15" Blue Wave Series Dual 4 Ohm Subwoofer need?
If its going in a single cab truck you won't have enough room. In a car you will need at least six inches. Might consider soundproofing the trunk if that's where they will be BC the vibration from the base will bounce off the walls and can blow your speakers??
May 30, 2015 | Pyle Car Audio & Video
Elan wall speaker mounts
Try Radio Shack, Best Buy, Sears, or eBay.
Apr 13, 2012 | Elan SEL350 Speaker
Trying to install kenwood kfc-1662s speakers in my 07 silverado crew cab and having problems mounting the speakers in. is there a mounting bracket that i need for them?
These speakers are not designed for your truck. I recomend asking chevy of what brands and what size speakers will fit in your truck.
May 15, 2011 | Kenwood Car Audio & Video
I need to know what I will need when installing Focal 165 A1 6 3/4 speakers in the doors of my 2003 Nissan Altima. (speakers adapter rings ect.?)
When putting in a good set up speakers like those, I always recommend:
Making mounting rings/plated for them
Sound Deadening Material to help seal the door up for better bass from the mids
Gasketing Foam to help decouple surfaces that may vibrate against each other
Duct tape
Good quality speaker wire.
Jan 09, 2011 | Focal Access 165 A1 Car Component System
I need to find out how to mount stereo MA-10D speakers to a wall. I can't see any mounting capabilities on the back, sides, top, or bottom of the speakers. Has anyone successfully mounted speakers like...
Hmmm. .U don't have option given for speakers to fix them onto the wall. You have to do the following steps.
Things U need are:
  • Masking Tape
  • Level
  • Pencil
  • Keyhole saw
  • UL Class 2 speaker wire
  • Fish tape
  1. Locate the studs closest to where you'd like to install your speaker. You'll want to install the speakers in between the studs.
  2. Tape the template that comes with the speakers in the center. Check to make sure your configuration is level and plumb. Your template will tell you exactly what size hole to drill to insert the speakers. Trace the opening you need to cut into the wall or ceiling
  3. Cut the hole using a keyhole saw or a drywall saw. Keep the section you cut open in case you can't install the speaker and need to patch the hole you just made. If the hole reveals plumbing, you need to relocate the speaker
  4. Run the speaker wire through the wall, or fish speaker wire from an existing installation.
  5. Install the brackets to support your speaker if one is included with your speakers. Some speakers use clips to secure them to the inside of the wall.
  6. Strip the protective coating from the end of the speaker wire, and insert it into the speaker jacks. Test your speakers now if the wires are attached to an audio source. If not, locate the other end of the speaker wire and hook it up. Testing now will save trouble if you run into problems.
  7. Surround the speaker with insulation to enhance the sound. Secure the speaker into place, and do any necessary patching or painting
Aug 27, 2010 | Roland MA-10D Main / Stereo Speaker
No sound from subwoofer, i have a JBL subwoofer the side or small speakers will play but the woofer will not i ran a sound check and it was stated that all speakers was working fine. could it be that my...
Are you using the Creative speaker test program? It usually has a picture of a generic layout of a pc system, with the speakers around it, showing a speaker for each that you should have plugged in. There should be a test button that will play a sound through each speaker. If a sound plays from your center speaker when the subwoofer picture is lit up then you may have a cord plugged in incorrectly on either the subwoofer or on the back of the soundcard. I've ran into this many times.
The best way to set up surround sound is to get your speakers placed or mounted on the wall, then run one wire at a time into the subwoofer, to ensure that the front left is hooked into the subwoofer in the front left, front right into front right, etc. Then once the speakers are hooked into the subwoofer start running the outputs from the subwooofer one at a time into the sound card. After each connection run the test program and watch the pictures light up as the sound plays, and make sure that the speaker playing sound in your place is the same speaker that is lit up on the test program.
I hope that helps, otherwise the amp is probably bad. Let me know if you need more help.
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
How to install the mounting bracket to JBL control 25?
big red
they allways have a screw in the back you just tighet it and level your speaker
Oct 17, 2009 | JBL Control 23 Speaker
M3 mounting bracket securing pins
Polk in the US are sending me a replacement pin. What great guys they are.
Sep 23, 2008 | Polk Audio M3 Speaker
Mounting under flat screen tv
There is no wall mount bracket for the VCS-10. It was not designed to be wall mounted. Your best solution is to mount a 22"x8" shelf to the wall 4-6" below the TV. Make sure it is mounted sturdy enough to support 10lbs.
Sep 05, 2008 | Bose VCS-10 Center Speaker
Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
May 24, 2008 | Denon AVR-1803 Receiver
Sony DAV-SC5 System Logo
110 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
