Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
USB Cable Lost my USB cable in move for MFC 440cn machine. Where can I order or buy a replacement cable.
  • unconnected Apr 02, 2008
    It appears to have a specific size port that does not take two of the USB cables I have around. I am thinking there is a specific cable for this machine?
  • 832 Answers
You can buy any usb-cable you like (at the supermarket or pc-shop etc.)! It should be no longer than 3m due to neg. effects on the scanner.
Posted on Apr 02, 2008
  • Mix-it-up
    Mix-it-up Apr 03, 2008
    No. Use a A-B USB cable.Do you try to plug in into the LAN port of the printer which is right besides the usb port?!
SOURCE:
What cable do I need to hook up my MFC-7220 fax machine so I am able to scan with it?
USB Printer cable is supplied along with printer.
If the original cable lost then you can buy a cable from any computer shop
Alexander
Apr 14, 2011 | Brother MFC-7220 All-In-One Laser Printer
My Brother MFC 440cn is on "offline", how ge it back to "online"?? Richard Lyman, Suffolk, VA
Check to make sure the usb cable is connected to the back of the printer and to the usb port on your computer. If your using a usb hub, remove and reconnect the printer cable. Windows should redetect it, but you may have to reboot.
Dec 22, 2010 | Brother MFC-440CN InkJet Printer
Brother mfc-440cn has error unable to print 4f
The service manual says it could possibly be a bad Main Board or a power supply problem, but it always turns out to be a broken printhead. If it's under warranty (one year) get to an authorized service center and Brother will cover all the costs except your time and gas. If it's just past warranty, call Brother's customer support and beg. Sometimes they issue work orders for warranty service on machines that are past their warranty.
If it's out of warranty, I'd recommend giving up on it. The parts are expensive, it's time-consuming (expensive), and you can buy a replacement machine pretty cheaply. www.BrotherMall.com lists refurbished, more advanced machines for $90.
Sep 20, 2010 | Brother MultiFunction Center MFC-440CN...
How do you connect to your computer
You can buy this cable or use the one provided by Brother
Belkin PRO USB 6' Cable USB cable, 4 pin USB Type A (M) - 4 pin USB Type B (M), 6 ft
Belkin Cable 4 pin USB type A (M) , 4 Pin USB type B (M)
Detail in this link
http://www.superwarehouse.com/Brother_MFC-3220C_5-in-1_Color_Multi-Function_Center/MFC3220C/p/332703
Apr 22, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
I need printer CD
You don't have to order a new one, for drivers for your MFC-440CN printer just open this link http://www.bioticaindia.com/mfc-440cn.html
Jan 26, 2010 | Brother MultiFunction Center MFC-440CN...
Usb cable
Players use standard USB, Mini USB, or Micro USB. I believe the one in title uses Mini USB cable.
To get a replacement cable go to any computer shop or camera shop and buy a Mini USB cable, take the player with you and show it to the shop assistant to ensure you are buying the right cable.
Regards.
Jul 05, 2009 | Supersonic SC920FM MP3 Player
Connecting my Brother MFC 440cn printer to the internet
It turns out my dad had the usb cable plugged into the ethernet port instead of the usb port. It works fine now.
Thanks for the response.
Oct 26, 2008 | Computers & Internet
Share printer
First you have to set up a home network between both your computers, once that is established run an networking cable to your printer it should all be ran through a networking hub so all machines can communicate with one another
Jul 05, 2008 | Brother MultiFunction Center MFC-440CN...
Brother USB Cable
Apr 02, 2008 | Brother MultiFunction Center MFC-440CN...
Window XP Media Center Edition won't boot up if Brother MFC-440CN is connected.
I would go first with Brother's support suggestion. You can always go back to the original BIOS setting.
Jul 27, 2007 | Brother MultiFunction Center MFC-440CN...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
51 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
