Audio Shelf Systems
Problem for Audio Shelf Systems
Generic problem for all Audio Shelf Systems
Power cutting out
By jonjon007 on Apr 02, 2008
hi i have a technics stereo and as i increase the volume it cuts out and returns to standby. It does it at various volumes.I have checked the wiring which seems to be in order. the speakers were the original sold with the appliance.I did put in headphone speakers to the socket and put the volume to full load and it did not cut out or switch off if that helps you ?
Same Problem
Sep 02, 2008
-   I am getting a system shut down after a few minutes of play. I have found that giving a hefty clout has the desired effect although this is probably not the best solution. However it keeps cutting out more frequently as time goes on. Also I get a NO DISC indicator when there is a clean disc loaded.
Driving me mad and I have a sore fist from hitting it!-   Swampy69
Solution #1
posted on Apr 02, 2008
Not Rated)
Abrsvcs
Rank: Guru  Home Audio  Expert
Rating: 88%, 1821 votes
The headphones are powered in a different fashion than the speakers and do not use anywhere near the power. The basic problem here is that you are likely getting DC current into the last output stage of the amp. This can be a failure of a part in the front end or within the output section itself. Depending upon your specific model, the repair cost could be as little as $15 for parts to over $75 for parts. Add in the local labor charge for the complete repair cost. If you can update this with the model number, I can provide yu with more specifics.
Dan
Was this helpful?
Yes
No
Popular Solutions for Audio Shelf Systems
Questions and Unsolved Problems for Audio Shelf Systems
Answer
Does the Sharp CD C602 have a light in the main window?
Answer
Crosley CD Jukebox. Bubble tube broke. Where can it be fixed? We're in Fort Wayne, IN.
Answer
I have a rca stero that won't read cd's anymore.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Audio Shelf Systems:
Top Audio Shelf System Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Audio Shelf System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
