Question about Sony NWZ-B103FBLK MP3 Player
When I turn it on it shows creating database and then it turns off
Hello, it was working fine, but after I transfer some long wav files a couple of days ago this problem came up, kaspersky detected a virus so I erased these files, then when I turned it on it showed creating database and it immediately turned off, I have tried resetting it, but it doesn't work, I haven't tried to format it with windows explorer, because the manual recommends to only format it inside the player, but obviously I can't do it, I don't know if I should try to format it with windows or do I need a firmware upgrade?
My sony mp3 player is only 3 months old, so I don't think it's the battery
What do you suggest?
Than you very much
  • joeysul87 Apr 11, 2008
    Yeap!! same here! have the same problem ! I even scan my mp3 for virus and it detected 20! then i deleted all unfortunately when unplugged, it turns off by itself without pressing the on/off button!
    please HELP!
    Master:
    Sergeant:
  • 462 Answers
Guys u need to keep one thing in mind while connecting players to pc.. make sure ur pc is free from virus.. its a must... its because of virus that can even ruin entirely ur players... do a update from the sony site to solve all the problems..
Posted on Aug 02, 2008
SOURCE:
Attach a database without the corrupted log file
There might be other options out there. This is something that worked for me once but there are no guarantees that it will work at all times.
Stop SQL Server instance -> Copy MDF and LDF files to another location -> Delete original MDF and LDF files -> Start SQL Server instance again -> Create new database with exact same name and file names -> Stop SQL Server -> overwrite newly created MDF and LDF.
After this your database should be back online. If it is then go ahead and put it into EMERGANCY mode and SINGLE USER mode.
Finally go ahead and execute DBCC CHECKDB like this
DBCC CHECKDB (databaseName, REPAIR_ALLOW_DATA_LOSS) WITH NO_INFOMSGS
More information you can dig out from resources directly connected with SQL Server databases and database corruption in MS SQL Server any version...
http://itknowledgeexchange.techtarget.com/itanswers/how-to-restore-mdf-file-as-bakcup-databe/
https://www.repairtoolbox.com/sqlserverrepair.html SQL Server Repair Toolbox
May 15, 2015 | Microsoft SQL Server 2008 Enterprise Full...
Creating a new database using an MDF file
An MDF file isn't a backup file isn't the main data file (or master data file depending on who you ask) hence the file extension MDF. You can attach the MDF to the database by right clicking on the databases folder in Enterprise Manager (SQL 2000) or Management Studio (SQL 2005) then selecting all tasks and then Attach Database.
When you do this you will get an error about the log file missing. This shouldn't matter as SQL Server will simply create a new log file for you.
This will only work if the SQL Server was stopped when you copied the MDF file from the old SQL Server. If you copied the file while the SQL Server was running this file probably will not attach either and you will need to get a valid backup of the database.
Download help tool for sql database - SQL Server Restore Toolbox.
http://www.sqlserver.restoretools.com/
You can read up more on SQL Server here.
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/498-creating-a-new-database-using-an-mdf-file?_=1416149856104/
Nov 16, 2014 | Microsoft SQL Server 2000 Standard Edition...
I have steinberg clean 4 & 5 but both versions only show CPF file choice .i want to save as wav.
On the File menu you will find an option named "Export Audiotrack as WAV" as well as "Export Audiotrack as MP3". This will allow you to Save or Export the files you create as either the .wav format or the .mp3 format. Check your Help file, specifically page 86, if you need further information.
Mar 17, 2011 | Pinnacle Steinberg Clean 4.0 (210100265)...
Using Adobe Acrobat 9, I have created a PDF e-book with .WAV audio attached to images (via the Sound tool). The images show as they should, and clicking on them activates them. Fairly simple. But when I...
I wanted to be specific about this line in the official post regarding attachment of sound to an acrobat file in version 9
QuickTime 6.0 or later is required to work with movies in InDesign. You can add QuickTime, AVI, MPEG, and SWF movies. However, QuickTime no longer offers full support of SWF files. You can also add WAV, AIF, and AU sound clips. InDesign supports only 8? or 16?bit WAV files that are not compressed.
These are the only official file formats of sound files which as per adobe can be attached with version 9 acrobat. You can go through rest of the article by clicking on the link below.
http://help.adobe.com/en_US/InDesign/6.0/WSC117AD88-69F6-4658-A1F1-12012B15B9D7.html
Feb 05, 2011 | Adobe Computers & Internet
Olympus DW 90 VN series. I have been using the
get switch audio converter software from www.nch.com.au
works for us like a charm
Aug 30, 2009 | Olympus VN-4100PC Digital Voice Recorder
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
Mar 21, 2009 | Olympus VN-4100PC Digital Voice Recorder
Problem importing files to Tascam DP02-cf
They don't mention in the manual that in addition to being 44.4khz, 16bit, mono, the wav file also has to be at a bit rate of 705kbps. Using Audacity (freeware) you can convert most any audio file into the necessary wav format for the DP-02cf to use.
Jan 24, 2009 | Tascam 2488 Portastudio Multitrack...
Load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Jan 10, 2009 | Tascam 2488 Portastudio Multitrack...
My philips gogear 2gb mp3 player will no accept any format
maybe try uninstall program on pc then put instalation disk back in and reinstall
Dec 31, 2008 | Philips GoGear SA3125/37 MP3 Player
Steps in saving file in excel to database
severals solution :
- save file as text separated by comma and use sqloader from oracle
- use function in excel to concatenate insert order : "insert into TABLE_NAME (field1,...,fieldn) values (A1,B1,...,??n);". Save file as text with sql extension. Connect against roacle db and execute file previously saved.
- use ODBC from MicroSoft
Dec 11, 2008 | Microsoft Computers & Internet
Sony NWZ-B103FBLK MP3 Player Logo
60 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
