Dear Sirs, I have a ILO DVD Recorder Model DVDRHDO4, which I bought 3 years ago. It worked fine until last week when I ran out of the Maxell 8X disks I was recording on. So I bought some 16X but they won't work. I have left several messages for their Company Techs to call me back, but have gotten no responce. Can someone tell me which disks to buy now or do I just toss this unit in the trash? Please let me know, Arline English
    Master:
  • 518 Answers
DVD 8X discs are abundant on Ebay. I perfer Memorex +R myself.
Hope that helps...
Geno
Posted on Apr 02, 2008
Ilo=R/RWDVD RECORDER,DVDRO4,CANNOT GET YOUR COMPANY TO ANSWER HEL
This unit only uses DVD +R or +RW. I have found the Maxell works the best with mine.
Mar 17, 2009 | iLO DVD Recorder DVDR05
Recording Error -- E7
When I bought my emerson ewr10d4 about 2-3 years ago, the machine only recorded on disks that were rated at 2x or 4x speed. And it didn't accept off-brand disks, it only liked the major brands like Maxell, TDK, Memorex, Sony. I learned this quirk the hard way. Eventually, when I called the 1-800 number, they sent me a disk to upgrade the recorder to 8x speed (and it was very simple to do - basically just pop it in). Helped a lot, although this year most disks in stores are 16x speed, and as of a couple months ago (November 2008) emerson didn't have a newer up-to-date upgrade available. But if you didn't do the 8x upgrade yet, call them and start there. It's a small improvement, but an improvement nonetheless. By the way, if anyone wants to buy some lesser-known chinese and japanese-brand disks, I may be able to help!
Dec 28, 2008 | Emerson EWR10D4 DVD Recorder
ILO DVR 04 Will Not read
your dvd writer is bad, because there is not enough air in side the box. it over heated, the fan inside is not big enough. you are one of the lucky ones, if yours even lasted a year. i had 4 go bad on me in six mouths returned to walmart and replaced them.open up your box and unplug the strap from the player and the power line from the back of the dvd recorder. if you have a computor the power and strap hook up the same.way. what you need to do, is order a dvd recorder on- line,a 8 speed and 20 speed will not work. it has to be a 16 speed dvd recorder.and a dual layer chould help. i got mine from sams it was a 16 speed LG internal super multi dvd/cd rewriter, but i think all they carry now is a 20 speed.if you get one, i would just leave the old one in ilo. and do a little carving on the back of the ilo caseing to run the strap and power cord through and ontop of the ilo. just sit the new recorder on top of the ilo it may not look good sitting there but it will last a lot longer that way i went through about 200 different brands of dvds before i found out what was wrong with mine good luck i hope you get it fixed. e-mail me if you have any quistens.thanks ronpar
Mar 29, 2008 | iLO DVDR04
Sylvania dvr90vf dvd recorder
Unfortunately without a firmware upgrade the only disks you can use are DVD-R or DVD-RW. The tricky part is that you can ONLY USE 2X speed. Per my conversation with Sylvania there is a firmware update that will allow you to use up to 8x disks, but they are charging $17.00 for it.
Feb 12, 2008 | Sylvania DVR90VE DVD Recorder/VCR
Incompatible disk message
You need to read page 8 of the JVC CU-VD20 DVD Burner instruction manual:
Recommended DVD-R Vendor - JVC, TDK, Verbatim, SONY
Writing Speed for DVD-R is 8X maximum, this is the real issue as I first bought 16X TDKs and they did not work, so now I need to buy 8X.
That's a bummer as most stores only supply 16X now.
Nov 30, 2007 | JVC Everio Share Station DVD Burner Burner
DVD won't record
check your dvd that may not be a recordable dvd. You have to use either DVD R+, R-, or rewritable RW+/- disk. where did you buy it?
Nov 24, 2007 | Symphonic WV806 DVD Player/VCR
Dvd recording
have you close the disc
Jul 26, 2007 | iLO DVD Recorder DVDR05
Ilo-DVDR04 recorder problems
The laser is either dirty or is starting to go.These lasers in this model usually only last two years.To clean but a commercial disc cleaner philips or Maxell work good in this model.Put a drop of rubbing alcohol on brushes this helps clean laser.I would do this every 15 hours of use .The best way to clean laser is to rub gently with a Qtip soaked in rubbing alcohol but this requires some technical knowledge for you have to open burner.If you attempt this make certain electrical plug is pulled lasers cause nasty burns.
If laser is going you can replace the burner/loader unit,this model uses a 411s or 451s Liteon burner.The 401s and 813s will also work without problem.
Jun 05, 2007 | iLO DVDRH04 DVD Recorder
I cant record
I posted this in another person's question but it is probably relevant to you as well. This model (which I own myself) is outdated and needs a firmware upgrade. You might get lucky and get one from their tech support. However, I heard they stopped shipping them nearly a year ago. As it stands your recorder can only use DVD-R that records at 4x (or lower) and DVD-RW that records at 1x. Any other media is useless. Since 4x media is outdated, it may be hard to find at a major retailer. Let me know if you have any luck fixing this or finding working DVDs as I have had the same issue myself. I simply cannot find 4x DVDs in the store.
Jun 01, 2007 | Emerson EWR20V4 DVD Recorder/VCR
ILo DVDR04 Recorder
your dvd writer is bad you will have to replace it believe me i now what im talking about i have went through 4 ilo's did the same thing plus 100's of differnt name brand dvd's
Feb 15, 2007 | iLO DVDR04
Televison & Video Logo
Top Televison & Video Experts
