Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Toyostove 72 solenoid pump won't work how do i check to see if it's the pump or it's not getting power
  • fireball10x Nov 25, 2008
    thanks i'll give it a try
  • 57 Answers
Chances are (just guessing) it's the pump. Is your display lit up? It isn't the power then. I replaced my pump. It was fairly easy to do. Just make sure you disconnect the power, and the fuel.
Posted on Oct 19, 2008
72 no power lights
There are 2the fuses on the circuit board. Be sure to check them both, and PLEASE, replace the bad one with an exact like and kind of fuse
Oct 24, 2012 | Rinnai Toyostove Direct Vent Heater:...
Low heat output. Older Laser 72. Does something
It's likely that the burner mat has came loose or it has a lot of carbon buildup in the burner. Look at the flame when the heater is on. It should be mostly blue with slight yellow tips. You might need to clean the fuel nozzle also. You can remove the fuel pipe where it connects to the burner and use a piece of wire or an allen wrench that will fit in the nozzle that goes into the burner to remove any carbon that may have built up. You can also clean the burner but don't destroy the mat in the bottom. You can find the owner's manual at toyostove.com and it will give you some more things to clean.
Apr 17, 2010 | Rinnai Toyostove Direct Vent Heater:...
I have an error EE 2 on my lazer 56 toyostove Does anyone know what that means?
EE 2 means its not getting fuel, your flame sensor could be dirty, or there could be a problem with the circuit board. The heater goes thru a 3 min warm-up/purge before the pump comes on. If the pump is making a loud ticking sound then it isn't getting fuel. You should then check your filter and the strainer in the fuel sump. If the pump isn't making a noise you could check the flame rod and clean it with some steel wool. You should check to make sure the igniter is working also. After you turn your heater on the cover on the igniter will start to get warm and will get very hot before the purge is done so use caution. Hope this helps.
Apr 03, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I was told my Toyostove Laser 72 stove needs to be cleaned. Can i do this myself and what do I do.
I would recomend having a qualified technican service your Toyo.
It IS possible to clean it yourself, but you will want to do it during a time that you aren't needing the heater to keep the space warm.
Certain parts can be hard to tell if they are working as they should if you aren't familar with what you're looking at.
With proper service, your Toyo will operate efficently, and likely last for a long time.
_Helping Hands Services_
- Fairbanks, Alaska -
Oct 05, 2009 | Rinnai Toyostove Direct Vent Heater:...
The reset button comes on for laser 72
The thumping noise is the fuel pump starving for fuel. It sould like you are having a fuel problem. NO fuel, low fuel, dirty filter.
Tom Hawkins
hawkins111@gci.net
Jan 03, 2009 | Rinnai Toyostove Direct Vent Heater:...
I have a monitor 2200 that is reading ee 13. what does that mean?
EE13 on a Monitor is one thing. The same code on a Toyostove is completely different. A Monitor EE13 means there was no flame at ignition. On a toyostove EE13 is the burner thermistor.
On the Monitor I would check my fuel tank. On the Toyo you may have to have the dealer help you, as it could be something easy like a very cold day or more complicated as a main circuit board.
Tom Hawkins
Bethel, Alaska
Dec 26, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a 41 monitor k1
I'm not real familiar with Monitor heaters, but if they are like Toyos, you may need to replace the pump.
Dec 02, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 55
sequence of operation is just like the monitor. combustion blower comes on to purge chamber of fumes. after the delay, the solenoid pump comes on and deposits fuel to the burner mat, within 20 sec the igniter comes on, incandesces and ignites the fuel if there is no flame, the flame rod is supposed to shut down heater and go into a lockout condition until shut off or unplugged to reset. check solenoid pump first. you already know the igniter works. check the fuel filter in the fuel sump might be clogged. check the fuel sump float valve, might be stuck, supposed to hang free in the sump with needle valve open. thermostat is digital just starts and shuts down the burner and solenoid pump.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 56 (F type) making loud humming noise
the toyostove is basically a glorified monitor heater.  its components are a combustion blower, an air circulator fan, a flame pot, a flat wick or burner mat, a solenoid pump, an ignition element, double  walled intake, exhaust pipe.   the combustion blower is a glorified vacuum cleaner motor. it sucks in cool air and channels it to the combustion chamber along the sides (round cylinder) kero enters on the burner mat where it ignites. the solenoid pump keeps adding kero until the flame detector spots or heats up. air flow to the pot is regulated by a damper in the combustion air blower line. if the "O" ring in the damper is missing or hardened it will not regulate the air flow which is necessary for combustion.  replace this "O" ring should take care of your problem.
Oct 17, 2007 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
352 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
