Question about ASUS A8N-SLI Deluxe Motherboard
Asus Mother Boards - Beeps, Boots, Windows Login Sound, No Image
I have an Asus motherboard, I have a three beeps, seems to boot, and then a windows login sound, but I don't have an image.
I don't remember if its 1 long with 2 short beeps or 3 short beeps, and can't check since I'm now at work and not in front of my busted PC back at home.
If Windows is loading (since it plays windows chime) does that mean its simply my Video Card?
  • Anonymous Jun 02, 2008
    I have the same problem... ASUS A8N-SLI-Deluxe... powers on... I get 3 short beeps....  and eventually I hear the windows loading sound... but all the time the screen is blank.
    The problem seems to happen more often on cold days... and only seems to happen when I have my Nvidia 6800GT in the system, an older Quadro worked fine for about a month with none of these problems.
    I have RMA's the graphics card and recieved a brand new one, replaced the power supply, messed around with Hard Drive Configs (Windows on PATA, Windows on SATA, Windows on SATA RAID 0) about the only piece's I haven't replaced at the CPU (Athlon 60 3800+) and the motherboard its self
  • 655 Answers
Yaa you are right. try to boot in Safe Mode and check out driver for display, otherwise you have to change your display card.......
thanks
iqbal
Posted on Apr 02, 2008
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
Computers doesn't startup and has no beep
remove the RAM chip and start the computer without the ram chip inserted and see if you get beeps if yes the motherboard/bios is ok, even if you dont get to hear any beeps, try rubbing the edge of the ram which goes into the ram slot using a Eraser and then reinsert the same back in Ram slot and then see if you can at least get to bios and see if hard disk is detected as windows boots from hard disk if yes check if you can boot to windows if no may need to reinstall windows.please reply with results so that can help
Feb 22, 2012 | Foxconn (945G7MA-8KS2) Motherboard
2 LONG BEEPS BUT THE PC STILL BOOTS mobo asus m4a785-m phenom ii x4 945 c3 4 gigs kinston ddr2 800 thermaltake 600w pny gtx 460
Beep codeswere first introduced by IBM on their first PC as a means of trouble shooting failures. The two long beeps are not familiar, but who knows. look at the following site for some of the Bios beep codes.
http://www.pantherproducts.co.uk/Articles/Motherboard/BIOSbeep.shtml#Phoenix BIOS
Jan 03, 2011 | ASUS M4A785M (890552666775) Motherboard
When I press the power button of my CPU i hear 3 Continuous beeps which repeats thrice. Again the beeps come during the windows login. This beep was not there in the begining. It started recently. But...
It is true that your computer is working properly without any trouble.Three continuous beeps means that your keyboard component is not ready to input the data.That's why it is calling you as beeps.You might have to check your keyboard that it is attached with the CPU properly or not.
Apr 06, 2010 | ASUS M4A79 Deluxe Motherboard
Asus k8s mx not boots but fan rotates and without
Long beeps are saying 'no RAM'. Any beeps with RAM in place? Remove BIOS battery (silver) for 10 mins to return to factory defaults.
Sep 12, 2009 | VIA Asus K8V-MX K8M800 Chipset 800MHz FSB...
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
No beeps or monitor signal
Sure, a motherboard can be a dud out of the box like any other part. If you have a known good power supply, processor and memory installed, and the machine doesn't boot and you have no video, the only thing left is a non-working motherboard. Return it to the vendor and get it exchanged as defective.
Jun 20, 2009 | ASUS M2N-VM DVI - Motherboard - micro ATX...
ASUS M2N-MX SE Plus mother board windows 2003 audio drivers
It is better to install   windows xp..  because   2003  is not supportting  latest mother boards.
only windows xp  will solve that problem
thank u.....
Nov 19, 2008 | ASUS M2N-MX Motherboard
ASUS P5VD1-X
When the computer boots you should be able to se if the mother board detects the hard drive.
if thats not so. go into the mother boards bios and have it set so that it auto see the hard drive,
Dec 14, 2007 | ASUS P5VD1-X (90MBL3C0G0EAYZ) Motherboard
ASUS A8N-SLI Deluxe Motherboard Logo
231 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
