1999 Dodge Intrepid Logo
A
Anonymous Posted on May 17, 2010
1999 Intrepid: my girlfriends front catalytic converter is out an...
My girlfriends front catalytic converter is out and the shop is charging her $850 so I was going to do it myself is this a difficult job?
Anonymous
Level 1:
New Friend:
  • Contributor 50 Answers
  • Posted on May 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
50
Questions
0
Helped
17584
Points
84
Idle drops, and stalls
Catalytic converter possibly
2answers
How do i remove catalytic converter from dodge intrepid?
Usually if they are bolted on the bolts are so rusty they will just break off. I use a sawzall to make a cut in front and back of the cat. Then the easiest way is to use clamps to install the new one.
4helpful
Check Engine light code P0432
P0432 - Main Catalyst Efficiency Below Threshold Bank 2
The ECM or PCM monitors the front an rear O2 sensors. The ECM or PCM detects Warm up Catalytic Converter when the sensors are out of specifications.
DTC is set when the ECM or PCM detects rear HO2S value difference becomes closer to value of front HO2S. The ECM or PCM monitors when vehicle speed is 25-60 MPH, load is 22-45 percent and engine speed is 1000-3000 RPM.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes
- Warm Up Three Way Catalytic converter deterioration or malfunction. - Exhaust system leaks. - Loose front or rear HO2Ss. - Front HO2S malfunction. - O2 sensors harness or connectors
Possible solution
- Replaced Catalytic Converter - Replaced rear O2 sensor - Repair wire harness or connectors
Check it ans tell us news.
1helpful
I need to know how many 02 sensors are on a 1997 dodge intrepid.
  • Up-stream sensor (located before catalytic converter)
  • Left up-stream sensor (located before catalytic converter)
  • Left down-stream sensor (located after catalytic converter)
  • Right up-stream sensor (located before catalytic converter)
  • Right down-stream sensor (located after catalytic converter)
4 sensors total.
I got a code po421 on my 99 mits mirage. Brought it to the shop they said it was either the front o2 sensor or the cat converter. I was told if I replace the cat I also got to replace the o2 sensors. If i...
It is not true that you have to replace the O2 sensors when you replace the catalytic converter. It is suggested, but not required. Most exhaust shops can test the catalytic converter for flow. before you spend the money to replace a part that does not need it.
1helpful
1helpful
2answers
Catalytic converter
The short answer is NO... It's not like changing a muffler in the "good old days". They are welded in and need to be cut out then rewelded, etc... not an easy job unless you have access to shop tools.
Can I ask WHY you need to change the converter??? They usually last as long as the car. I recntly sold a 1998 Olds with 245,000 miles on it and it had the original converter intact.
Good Luck
1helpful
How to replace/remove both catalytic converters
Below are the steps needed to remove the catalytic converters. You may be able to first remove the band clamp from between the converter and the exhaust manifold, then loosen the rest of the system and to get enough clearance to slide the converter towards the front of the vehicle but you will need to first remove the clamp that holds the converter to the rest of the exhaust. Hope this helps
_______________________
Both Catalytic Convertors
First you need to raise the vehicle.
Next, you need to pry the insulators from the support brackets and support the muffler and tailpipe with jackstands.
Then, loosen the the catalytic converter down pipe-to-front resonator clamps and separate the front resonator from the converter down-pipes. Carefully lay the free laying exhaust on the ground.
Right Catalytic Converter
Then, remove the down-pipe-to-transaxle bracket nut, loosen the clamp and separate the extension pipe from the converter.
Next lower the vehicle and remove the air filter and intake ducts. Disconnect the wiring harness for the O2 sensor and the remove the sensor.
Finally loosen the band clamp at the exhaust manifold and remove the converter from the engine compartment. You may need to replace these clamps after removal because you need to pry it apart and they will leak when you reinstall.
Left Catalytic Converter
Now disconnect the wiring harness for the O2 sensor and the remove the sensor.
Next remove the down-pipe-to-transaxle bracket nut
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
