Question about Neff U1721 Double circotherm Electric Oven
Can not remove element
I have a replacement element for Neff fan double oven u1721n2gb/01 but can not seem to completly remove the old element the problem seems to be the top connection, it looks like if i could remove the fan then this would not be a problem. Please help as this seems like a simple job . thanks
  • emergencysto Apr 19, 2008
    I have got a new element but there is a screw i need to remove to get the old element out that is situated behind the fan. Any clues as to how to remove the fan? Nut comes off, and a washer but then there is a clip still in place that wont budge.
Hi there. Dunno if you solved your problem but I had exactly the same. I did a bit of digging on this website and found the solution which worked. Basically, undo the three bolts holding the fan motor onto the back of the unit. This should allow enough play on the fan from the inside to wiggle (technical term) the bolt free and replace on the new element. Reposition and secure the motor. Hope this helps. Matt
Posted on Apr 28, 2008
NEFF U1271 Oven overheating
Hi it could well be the thermosat has stopped working
Jan 24, 2010 | Neff U1721 Double circotherm Electric Oven
Tip
Common heating faults with Neff U1421 Double oven,
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1421 Double circotherm Electric Oven
Tip
Common heating faults with Neff U1461 Double oven
on Jan 19, 2010 | Neff U1461 Double circotherm plus Electric...
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Lower oven not heating up everything else is working fine
hi, we have had the same problem. You can order the element from many places online, the cheapest is about £25 ranging up to £60 from neff themselves. Fitting it is ok the hardest part is getting the fan off to change the actual element. However, be warned, we are now on our 4th element and it just went again last night. Neff deny that this is a known fault that the elements keep going. However, at least 10 of our neighbours have had the same problem with their oven too!
Jan 18, 2009 | Neff U1721 Double circotherm Electric Oven
Tip
Neff U1452 Double oven Common heating faults,
For all Free appliance repair videos visit our VIDEOTUTORIALS
1, If the Neff fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1452 Double circotherm plus Electric...
Tip
Common heating faults with Neff U1661 Double oven
on Jan 19, 2010 | Neff U1661 Double circotherm super...
No heat generated in lower oven
You are quite correct in saying that the element has failed.
As regards the wattage , it should be stamped on the fixing plate of the element, if you cannot see it there then opt for the lower wattage one, it will not make much difference to the oven ,as there is only100watt difference between the 2., and that is nothing to worry about.
Plz rate my solution to your prob.
Thanks.
Jan 03, 2009 | Neff U1721 Double circotherm Electric Oven
Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Apr 18, 2008 | Neff U1721 Double circotherm Electric Oven
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
400 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
