Question about Microsoft Windows Vista Ultimate Edition
Vista face pack for xp
I down loaded the vista face pack for xp but when i run the exe file it stops and message is displyed ....has experienced a problem and needs to close. what do i do?
  • 61 Answers
I belive there is software where you don't need to download must your computer will look like Vista and a few files will change the theme and other stuff will change like the logon screen if you would like to get this email me admin@jdpmedia.net.tc then i should think your problems are over.
Posted on Apr 02, 2008
Having issues running Cruise Ship Tycoon (Activision 2003) on my PC. It's a HP with Windows Vista. I click on play and it won't load.
Try running in compatibility mode right click on the shortcut or exe file go down and select properties and then the compatibility tab and run in windows xp service pack 3. This should get the program to run. Hope it helps Kidromulous
Mar 08, 2011 | Computers & Internet
I cant find software drivers for nv-gs11 mini dv camthe drivers i got wont load up onto vista
Here is how to Install them so they MAY work. Download your driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file AS ADMINISTRATOR and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all Also use all software used by it AS ADMINISTRATOR too.
Mar 01, 2010 | Panasonic NV-GS11gc Mini DV Digital...
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
Scrapland and vista, error starting game - solution?
my friend you can go to launcher.exe and
1 right click and properties .
2 compatibility and then select mode windows XP/nt
click on the other icons try it works.
reply about the result.
Mar 28, 2009 | Enlight Interactive Scrapland for Windows
Error 301b(1805) for olympus p400 printer
The driver for the P-400 printer will work in Windows Vista. To install it you will need to install it in Windows compatibility mode XP service pack 2. Download the P-400 driver to your desktop from the Olympus website. Open the zip file, right click the mouse on the setup.exe file then left click on Properties. There will be a compatibility tab there. Select XP Service pack 2 and then click Ok. Connect the printer to the computer and direct the found new hardware wizard to the folder for the files it needs to load the device driver for the printer. If this does not work, you may want to call Olympus Tech support for assistance. Their telephone number is 888-553-4448.
Feb 12, 2009 | Olympus P 400 Thermal Printer
Olympus P440 Dose not work on Vista
The driver for the P-440 printer will work in Windows Vista. To install it you will need to run it in Windows compatibility mode XP service pack 2. Download the P-440 driver to your desktop from the olympusamerica.com website. Open the zip file, right click the mouse on the setup.exe file then left click on Properties. There will be a compatibility tab there. Select XP Service pack 2 and then click Ok. Connect the printer and as it goes through the found new hardware wizard direct to the folder location on your desktop for the files it needs to load the device driver.
Nov 17, 2008 | Olympus P-440 Thermal Photo Printer
Transforming XP to Vista platform
Leave Vista Transformation Pack on it's place and use "Windows Vista Mizer". It is the best software to convert windows Xp into Vista you can convert to any edition of vista and also make bootable vista disc,
try this download link for Windows Vista mizer
http://www.softpedia.com/progDownload/VistaMizer-Download-74379.html
Oct 12, 2008 | Microsoft Windows Vista Ultimate Edition
Epson Stylus Photo R200 and R320 Status monitor in Vista
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
E_S1LAC2.EXE
E_SCHK02.EXE
E_SIINS2.EXE
E_SPSU02.EXE
STMSETUP.EXE
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
Aug 03, 2008 | Epson Stylus Photo R200 InkJet Printer
Halo 2 for pc
The reason is, it only happens when you try to install Halo 2 on Windows XP.
The Game gets installed perfectly on Windows Vista
Because, I have installed and played the game on Windows Vista. But, when I de-graded my OS to Windows XP and tried to install the game. It gave me the same error message.
So, if your OS is Win XP then try install on Win Vista if you have it or on your friends PC.
But if you are already on Win Vista then please do let me know.
Also could please let me know whether your trying to Auto install the game or you are manually trying to install the game by clicking Step.exe?
I would be glad to find some help for you in this regard.
Jul 27, 2008 | Microsoft Halo 2 for Windows
Software won't work with vista
Uninstall Windows Vista. Do a fresh install of Windows XP Professional Sp2. Download XP drivers and install camera. Many software programs have trouble initializing in Windows Vista. Good luck!
Oct 12, 2007 | Microsoft LifeCam VX-6000 Webcam
Microsoft Windows Vista Ultimate Edition Logo
357 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
