Rebooting uhm...i'm just wondering whether rebooting the computer erase all files ...does it?
  • 655 Answers
Its depends on how you make reboot.
  • If you are making hard-reboot means just powering off the power supply, then you may be lost some data or files if they are open.
  • If you are making soft-reboot i.e. from Start->Shutdown -> Restart, then you are not going to loose any bit of information or data.
If any more query just Ask me please......
Thanks
Iqbal
Posted on Apr 02, 2008
SOURCE:
How to create a reboot disk? and how to reboot?
I you go to file hippo and down load a free program called ccleaner and then run the clean then the registry scan for issues but save the back up file. That should bring you back to good speed. also at file hippo malware bite is free also for a scan for malware which can slow your computer down. Hope this helps.
Mar 09, 2015 | Acer Aspire Computers & Internet
My laptop wont load right and nothing working on it. i can't reboot or trune it off. it won't run in safemood
Try booting from your recovery disk, then click "repair my computer". That should replace any corrupt files, and will not erase files on your computer. Very handy.
Oct 24, 2010 | Computers & Internet
How to reboot a computer with erasing hard drive
You need to get a little more familiar with terminology; 'reboot' simply means restart and while PCs start from the hard drive, erasing the drive means making the hard drive momentarily empty of data or system files.
Did you mean 'reformat?' This can make the drive empty of any recoverable files if done properly or, if done with the quicker method, it simply makes the file names different and unusable meaning the content can be recovered if desired.
If you are trying to destroy existing data but want to preserve the operating system, there are numerous free utilities that will do that securely and remove sensitive material.
I use this one for secure deletions, it's pretty simple and easy to use and can make any data totally 'gone' by several different methods.
Eraser
May 19, 2010 | E-Machines eMachines Desktop PC
Erased frontpage
When you say you erased it, do you mean you deleted the files from the Program Files directory or do you mean you uninstalled it?  If you uninstalled it you will need the original disk to reinstall it.  If you just deleted the files (bad move by the way) then you may be lucky.  Copy the files from the other machine and it may work.
May 18, 2009 | Gateway MT3705 Notebook
Iam from pakistan
The fix starts by first doing a "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers.
You should have downloaded the most recent catalyst drivers from ATI that are available for your card.
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are done. You may want to reinstall your ATI MMC software and DVD software if you use them. DONE!
Jan 01, 2009 | ATI All-in-Wonder X800 XL, (256 MB) PCI...
Can't re-install the soft. 4 files from Registry unable to delete
NICK, GO TO START RUN RIGHT CLICK MY COMPUTER..THEN PROPERTIES...HARDWARE..DEVICE MANAGER..FIND CAM(USB DEVICE)TELL IT TO UPDATE DRIVERS.IF THAT DOES NOT WORK AFTER A REBOOT THEN DO THE SAME BUT UNINSTALL DRIVERS AND REBOOT.THEN DOWNLOAD LATEST DRIVERS. REBOOT AND SYSTEM SHOULD DETECT CAM AND INSTALL.RICHARDM69
Dec 03, 2008 | Microsoft LifeCam VX-3000 Web Camera
Dell computer running slow
Take your dell recovery cd , install it in your computer,
reboot your computer,
when your computer states to hit any key hit any key and
follow all onscreen instructions
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 15, 2008 | Dell Microsoft Windows XP Home Edition
Sansa automatically erasing files?
next time you go to rhapsody right click the button that has you mp3s name an choose fomat device it will erase all files on your mp3 so you can put them back on
May 12, 2007 | SanDisk Sansa e260 MP3 Player
Open Questions:
SBCglobal MAil CuStOMeR {1^855^536^5666}#[email protected] Service NuMbER TEXAS This SbcGlObAl mAiL USA phone number is ranked #2 out of 2 because 7,728 SbcGlObAl mAiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbcGlObAl mAiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbcGlObAl mAiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbcGlObAl mAiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbcGlObAl mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbcGlObAl mAiL USA Calling SbcGlObAl mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbcGlObAl mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbcGlObAl mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbcGlObAl mAiL USA's phone numbers against each other. Contacting SbcGlObAl mAiL USA in General While I********** is SbcGlObAl mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbcGlObAl mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbcGlObAl mAiL USA.
Oct 21, 2019 | Best Computers & Internet
Computers & Internet Logo
173 people viewed this question
Ekse
Marvin
Marvin
