Question about Panasonic AG-1980 S-VHS VCR
H02 Error Message
My AG-1980 immediately powers down and displays a H02 error message when powered up. There is a tape stuck in the deck. What does the error message mean. Possible fix.
  • Kike Giuria Apr 15, 2008
    My AG-1980 powers down and displays a H02 error message when powered up. Please notify me how can I fix it.
  • Ultrago May 11, 2010
    Have same problem!
    Were you able to fix yours? Would appreciate that tip
    Champion:
  • 221 Answers
H02 error on AG-1980 is a "capstan motor error." most likely problem is a defective capstan motor.
Posted on May 28, 2008
SOURCE:
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
Colour Noise and Dim Display
Did you try cleaning the tape head of the player?
For some reason be sure all the gear or any mechanical inside the player is freely rotating.
Adjust the VCR tracking to get a good picture.
Feb 19, 2008 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1350: tape is stuck in deck (error "F03")
The commercial tape deck requires servicing. The tape is not spooling correctly due to worn parts.
Mar 04, 2011 | Televison & Video
AG-DVC30 "no tape in camera" error message
thats probly the cass in swicth
or a dirty sensor....
hope that will help..
Mar 01, 2010 | Panasonic AG-DVC30 Mini DV Digital...
Was looking to buy one, and before the seller
the tape deck has jumped timing and can cost 40 to 100 dollars depending on how quick it takes the tech
Jan 05, 2010 | Panasonic AG-1980 S-VHS VCR
No power. led display very dim
dim display on an ag-1980 may be caused by bad display module or bad electrolytic capacitors in the display power supply. "no power" is probably a bad 12 volt regulator on the main board. the main power supply is working as evidenced by the display lighting up.
Jul 03, 2009 | Panasonic AG-1980 S-VHS VCR
The main light on the front panel went out on my 1980 desk editior. how much to repair?
The display on the AG-1980 goes dim mostly from old age - replacement of the display usually cures the problem, though you may need to replace some or all capacitors in the power supply.
Jan 22, 2009 | Panasonic AG-1980 S-VHS VCR
Will not power up at all!
check the main board for bad solder connections near the power connection.
Oct 28, 2008 | Panasonic AG-DV1000 Mini DV VCR
AG-DV1000 Mini DV
The message indicates that an internal problem was detected and that the unit has shut down to prevent damage to the tape. The tape will need to be removed by hand. I can not receommend a repair location without knowing where you are.
Can you post an update with your location?
Thanks,
Dan
Aug 19, 2008 | Panasonic AG-DV1000 Mini DV VCR
Power down - F 04 error
These are good old VCRs probably in need of a belt overhaul.
Try unpluging the unit for 2 minutes and see if the error message is reset.
Oct 26, 2007 | Panasonic AG-1980 S-VHS VCR
Panasonic AG-1980 S-VHS VCR Logo
1,132 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
