Question about Avermedia AVerKey Plus (AVERKEY-PC)
Averkey Unit powers up but will not show a picture on the TV. Was working previous day. I have check all cords and even replaced them with ones from another averkey but still no picture.
Posted on Oct 16, 2008
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
I got a new Sanyo Vizion 46" LCD tv as a present about 2 weeks ago. I noticed since the first day when I change channels I can still see some images of the previous channel I was watching. Should I...
Return the tv for another one for the replacement.This tv have a problems,call a delay prograssive scan.That why u see the jet trails of the previous pictures.This problems,will not go away,but will getting worse and even might have a permanent pictures screen burn of the previous pictures in LCD screen panel too.
Nov 29, 2010 | Sanyo DP46849 46 in. HDTV
AKAI LCT2016 20" LCD TV- Dosn't Resize picture properly
U can't fix this problems.Omly replaced board.The Tuner main board have dead componnents.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner signal board for replacement.
Feb 20, 2010 | Akai LCT2016 20 in. LCD Television
TV won't show picture
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 08, 2017 | LG 42LB1DRA 42 in. LCD Television
I have the power cord dvd cords and cable cords plugged in and there is no picture the tv wont turn on it should turn on but it wont it wont even show that its off
Have you verified #1 that your outlet is putting out 120 VAC? Have to checked input power fuse inside chasis? What about a stuck power on switch? Unplug all access. except the TV and try powering it on.
Jul 31, 2009 | Dell W3000 30 in. HD-Ready LCD Television
After storm tv sutt off
disconnect all cords and power -- wait one day - then re connect and power up -- check internal fuses also -- if this doesnt work -- replace the power supply board
Mar 03, 2009 | Televison & Video
Power problem
If you don't have any indicators working, you have probably lost your power supply. With no picture and no sound the chances are you have either lost the power supply or blown a fuse. If you remove the cover and look at the circuit board there is a fuse located near the rear of the chassis near where the power cord connects to the chassis. If the fuse is blown, it is advisable to replace your damaged power cord before replacing the fuse. The cord could have a short and this could create a fire. Be very careful when working on any television. Be sure it is unplugged for more than one day to allow the high voltage to decay from the picture tube. Do not touch the picture tube, it still may have some residual voltage and could shock you. If you replace the cord and fuse and still have the same problem, you will probably find that the high voltage transistor is bad and needs to be replaced.
Jerry
Nov 07, 2008 | Philips 36PT842H 36" TV
Scott HDTV model LCT37SHA
We have just been working on this exact problem and have a page with all the details -
http://www.findonefindall.com/toyota-sienna/LCT37SHA_Scott_Akai_LG_LCD_TV.htm
Hope it helps!
Oct 26, 2008 | Akai LCT3201AD 32 in. LCD Television
Problem, please help
The unit should be under warranty. What you're describing is not normal and I would attempt to get a replacement from the place of purchase or take the unit to an authorized repair center. Below is the Philips support page for your unit. You can check warranty status as well as request repair.
Philips 42PFL5332D/37
Dec 07, 2007 | Philips 42PFL5332D 42 in. LCD Television
Avermedia AVerKey Plus (AVERKEY-PC) Logo
536 people viewed this question
Top Avermedia Televison & Video Experts
Alun Cox
Are you an Avermedia Televison and Video Expert? Answer questions, earn points and help others
