TV problem I have a Sony model # Kp-53HS30 projection TV. Last night was working fine. This morning the picture is blurry, and colors are not right. The captions at the bottom are are not strait accross, kind of rainbow shaped. Help!
I have a Mitsubisi TV receier moel c204701536
I have a cable but channals from 29 to 59 do not work the rest id fine.
Posted on Apr 02, 2008
SOURCE:
I have a Sony KP-53HS30 projection TV. The picture is clear for 2 minutes after I turn TV on after that the red color spreads around all light colors on the TV making it unwatchable. Is there a way I can...
Tv have a convergence problems,it dead.The tv convergence board is dead.The tv convergence board,must be replaced like 2 STK convergence ICS and some or all of resistors too.Will fix the tv convergence board,to solved tv convergence picture problems.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.
Mar 14, 2011 | Sony KP-53HS30 53" Rear Projection...
I recently bought a Sony KP-53HS30 rear video TV
Hello Sarah!
There is no bulb to replace in your TV. Image is created by three CRT's and you don't want to replace them, just trust me on that one. It could cost you up to $1800 to do that.
All you can do is to clean lenses of those CRT's. You have to disconnect TV from the power outlet and remove rear cover. Using very soft brush and vacuum cleaner remove dust from Red, Green and Blue CRT lenses. Do not use solutions unless you got something special for optics. Solutions will leave film on the surfaces. That would improve brightness and contrast of image.
To adjust focus front grille have to be removed. Than central piece cover held by 5 screws. Behind it you can locate black plastic "box" size little smaller than cigarette pack. there are 6 adjustment "screws". Three of them are "screen". You don't touch those. Another three "focus" there is one for each color. Turn TV on. Hit "menu" button. And adjust focus for each color separately. If menu goes away hit it again.
This is the only improvements you can do.
Everything else will involve humongous amounts of cash.
Russ.
Apr 04, 2010 | Sony KP-53HS30 53" Rear Projection...
KP-57HW40 rear projection TV colors out of alignment and warped
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2010 | Sony KP-57HW40 57" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony kp-53hs30 rear projection TV
replace the two convergence ICs and a couple 3.5 amp pico fuses. You need STK 392-560 convergence ICs. You can get replacment ICs and pico fuses at the following link. with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Aug 15, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony projection tv kp-53hs30 made nov.2003
do you think you can take a picture and send it to this website
Aug 08, 2008 | Sony KP-53HS30 53" Rear Projection...
Red ghosting on rear projection sony tv year 2002 how to fix
The model number is KP-53HS30, the screen is blurry displayin colors of red green pink
Jun 30, 2008 | Televison & Video
Sony KP-53HS30
sent the info to your email address
Mar 31, 2008 | Sony KP-53HS30 53" Rear Projection...
Kp-53hs30 won't power up.
joeysmoke,find technician you can trust privately,and let him fix at home,tell him to concentrate on the power board of the tv.
May 12, 2007 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
Ekse
