Question about NetGear RangeMax NEXT WNR834B Wireless Router
Have vonage fax and phone service
Phone works fine; fax machine cannot receive faxes but can send them; I've worked with vonage for 4-5 hours x 3 days, no solutions. Tech friend suggested it could be netgear firewall, but fax connects direct to vonage router which connects direct to cable router. Can you help?
  • MangumPI Oct 25, 2008
    I have call vantage from ATT and have the same symptons. Please help...thanks.
I am new in the network field.How can i set up a LAN net work using 5 hosts.What are the devices that I need to set up this net work?This is my email address.You can send it there:tunjiman23@yahoo.com.Mnay thanks
Posted on Apr 02, 2008
I have a new phone carrier(Vonage) and a new DSL modem from at&t. Prior to obtaining either, my fax machine worked fine. Now, I can't send or receive faxes..(Why)
This is a common issue with all fax machines that use a voip service. Basically, the reception and transmission features of the fax machine are not compatible with voip service. There is a modification that you can perform that usually allows you to avoid this problem, you must lower all transmission and reception speeds of the fax modem; this allows the data to be properly carried over the line without much loss or degradation.
-David.
Nov 03, 2010 | HP 1040 Plain Paper Inkjet Fax
HP 3380 All-in-one. wont send faxes. dials, says connecting, and even sometimes starts to send page, but comes up comm error. I have vonage phone service.
Vonage claims to work with all fax machines. However, some customers report having had trouble sending and/or receiving faxes with Vonage and other voice-over IP (VoIP) providers. The difficulties are a frequent topic in help forums and even made the Wikipedia entry for Vonage. Frustratingly, the problems have been intermittent and hard to diagnose, and some customers have resorted to buying a new fax machine that better-suits Vonage’s optimum specifications. The company’s official “help” resource suggests lowering the baud rate on the fax machine to 9600 (or “slow”) as well as disabling the machine’s ECM (error correction mode) feature, if applicable. Also, make sure the fax machine is on the “standard” setting. Some users have had good luck adding *99 before dialing, as that resets the bandwidth for that call.
Vonage also allows its customers to send faxes over the Internet, without a fax machine, by uploading documents to the Vonage web site. There is no additional charge for this service if you’re on the company’s “Unlimited Plan.” Per-minute customers will see fax use applied toward their monthly minutes allowance. Hope this helps.
Apr 20, 2010 | HP LaserJet 3380 All-In-One Printer
Can no longer send/receive faxes since switching to digital phone
hi
fax does not work on digital line it only works on analog line........if u want our technician expert then contact us athttp://tinyurl.com/ldnuy2
Jun 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Can't send or receive
fax machines are analog devices and will not work reliably on a digital phone line.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Can't fax long distance now-
Do you have a DIGITAL phone service like Vonage?
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line..
Dec 17, 2008 | HP Officejet 5510 All-In-One Thermal...
Can't Send or Receive Faxes from MFC-7820 N
You may not need a separate fax line from Vonage. If you don't need a dedicated fax line, you can try changing the "Bandwidth Saver" settings on your Vonage voice line from your account on the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
If your fax machine has a Telephone Answering Device (TAD) setting, you can share your voice line with your fax machine and be able to receive faxes and voice messages. Hopefully this will work for you.
Dave Grannas
Nov 04, 2008 | Brother MFC-7820N Printer
HP 5610xi All-in-one wont send fax since switching from Vonage to Comcast
the 5610 will send & recive with comcast try to do the test from the unit itself. Try to send a test fax to HP 1-888-473-2963 it will send you a return fax
Jul 11, 2008 | HP Officejet 5610 All-In-One InkJet...
Can't send fax
Greetings,
Seems that you accidentally ended the chat session.
Here's what i got, your phone service is on VOIP
VoIP is voice transmission over a broadband Internet connection instead of a standard phone line. Basically, Vonage converts your voice into data and sends it like an email.
Fax machines, like yours, are designed to work with the regular phone lines. As your phone line is digital, the functionality of your all-in-one printer & fax cannot be guaranteed.
Vonage also offers a dedicated fax service and you might want inquire them about that.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 05, 2008 | Canon PIXMA MX310 All-In-One Printer
Trouble faxing and receiving fax from "Brother 575".Can you help me with my fax machine? I have vonage, and I still can't receive any faxes. The machine makes copies, and receives calls,send faxes, but not...
Try changing the "Bandwidth Saver" settings on your Vonage account from the Vonage website. Perform the following:
Dave Grannas
Jun 01, 2008 | Brother FAX-575 Plain Paper Thermal
Vonage vs Brither 4100
Have you called your own fax line and just listened to the fax hand shake? might sound simple but I have called fax lines before and it just rang, or it was busy or static, if your not getting a clear fax hand shake, then it is the phone line, if there is no answer you may have turned your fax to manual receive mode, If you don't know how it should sound call a friends business fax line and listen to it. I have actually gone out to businesses that reported send or receive problems just to call the line and listen to a disconnect message, that would make it difficult to fax.
Jan 13, 2008 | Brother IntelliFax-4100e Fax
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
102 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
