Question about AEG B1180-4 Electric Single Oven
My AEG oven is switching off by it self after about ten minutes.
AEG compitance oven swithes off by it self what can I do???
  • mcbride May 07, 2008
    My aeg oven switches itself off after 10 minutes
  • dom24 Jun 19, 2008
    cooker heats up fan runs for ten mins or so then fan cuts out and light goes out
Think it shutting of as its getting to hot
Posted on Jun 19, 2008
Frigidaire Oven door wont open after self clean cool down
Good Morning Marlyn Allen, thanks for your post!
Based off the information you have provided your Frigidaire oven door will not open after it has cooled down. I would hold down the clear or cancel button for ten seconds that should release the door. If that does not work I would perform a reset on your oven and you can do that by disconnecting the power from it for approximately ten minutes. You can also perform another self-cleaning cycle and before it starts cancel the self-cleaning and then wait for ten seconds and the door should release. If you follow these steps and the door does not open it could be a faulty door latch and that would need to be replaced by a technician. Best of luck! -Matt
Dec 12, 2014 | Frigidaire Ovens
Stoves 720EF oven switches off after 20 minutes
CHECK THAT THE OVEN TIMER IS OFF AND NOT OPERATING EVERYTIME YOU TURN THE OVEN ON IT AUTOMATICALLY SWITHES THE OVEN OFF AFTER 20 MINUTES
Oct 16, 2014 | Ovens
Ask a question yesterday did not get an answer .i will ask again kenmore self cleaning oven tried to clean pressed button door locked .after ten minutes oven did not heat up to clean did i miss a step that...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 09, 2010 | Kenmore Ovens
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
My AEG pyrolytic oven won't run the cleaning cycle.
clean it the old fashioned way with aerosol oven cleaner . then use oven shields or pans under things to catch drips .
Oct 31, 2017 | AEG B5741-4 Electric Single Oven
NEFF HOB
Your heater is probably equipped with a bimetal thermal switch to prevent overheating and, if it is like most made in China now, it is defective or at least highly inaccurate. If you can locate the device, using a metal shield to divert some of the heat will help it serve its original function as a safety. Look for a thick (4-5 mm), button-like device with two terminals and a diameter of 1.5-2.0 cm.
This point of failure is shared with a majority of drip coffee makers that fail way too early.
Oct 18, 2008 | AEG B1180-4 Electric Single Oven
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Oven cuts out after ten minutes and comes back after cooling down.
thermal cut out fuse, costs about £30, my company fits them for £78 all in in essex
Nov 19, 2007 | AEG B3101-4 Electric Single Oven
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
AEG B1180-4 Electric Single Oven Logo
352 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
