Question about KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
Door noise I have two of these models and both have the same horrific, grinding noise when you open the door. It seems to be coming from inside the door - not at the hinge. Lubricating the hinge did not work.
  • 7 Answers
Common issue with this dishwasher. Easy fix though!! KitchenAid uses a nylon string that connects the hinges to the springs located along the bottom edges of the dishwasher. I had to pull mine out to perform this service. The nylon string seems to dry out and vibrates as the door opens and closes. All that needs to be done is put some Vaseline or other appropriate lubrication all over the nylon string. Especially where it passes through the roller and stationary guide. That will take care of any squeeking or grinding when opening or closing the door. Be careful as your door will now open just like it did when it was new. Now if I can only figure out how to keep my door from popping open during wash cycles!!!
Posted on Jan 14, 2009
  • 1,073 Answers
Door springs hitting something
Posted on Apr 22, 2008
I have a odd grinding Noise only when I'm driving this 2 door 1994 Mercury Topaz Car
check the wheel bearings for failure
check the disc rotors fir failure on the inside from brake pads worn out
Nov 20, 2015 | 1994 Mercury Topaz
Loud, grinding noise from garage door opener
Remove the cover from the motor housing and check the drive gear.
Jul 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
Starter made a horrific "
Do not turn the engine over any more than you have . You must un-hook battery terminal positive
grounds is ok , You have to take power cable from starter . now take the starter off the bike, when
it gets lose do not use force , just ease it out. Try not to leave any of spring , gear,pin, washer , housing . leave nothing . remove starter to a table close by. look starter over good, see if you can
see pieces missing . If housing is not craked or broken and the shaft, gear and pin are all intact?
Then it broke inside of the starter and that is a good thing . You have to check everything inside
starter housing on the motor, make sure no nothing has left a scar in side, if nothing is visual ?
This is good, but you still have to take the starter to someone that can identify the problem .
Once they have cleared you to put a new starter back on, you may do so . But please find out
why it broke before you put the next one in there.
Nov 18, 2010 | Harley Davidson FXD Dyna Super Glide...
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
1995 Olds Achieva S Grinding upon starting
They make that kind of noise if its low on fluid, and also depending on how cold it is they will make a lot of noise because the colder it is the thicker the oil is and the harder it is to pump. I am not there to hear the starter, If the starter is making noise it will only be audiable while your on start, i dought starter will make that noise while its running unless the drive is sticking . Have both the pump and starter chk.out.
Mar 30, 2009 | 1995 Oldsmobile Achieva
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
LG Refrigerator/Freezer Model GR-762DEQF
you will need to replace the fan the reason it stops it the door switch needs to be closed for the fan to operate. with the door open press the switch and see if that is in fact where the noise is coming from if so it sounds like the bearings are going out
Feb 16, 2008 | Refrigerators
KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher Logo
379 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
