Question about Refrigerators
Refridgerator not cooling off, but freezer is working. Fridge is only 3 years old.
  • 109 Answers
Check to see if fan is running in the freezer, if not replace fan. this is the usual problem, however may be more than that. you may have a defrost issue, by removing the back cover in the freezer side you can tell if the coils look like a block of ice or not.(not supposed to). if so check defrost components, defrost heater, defrost thermostat, and defrost timer.
Posted on Apr 03, 2008
  • 1462 Answers
SOURCE: freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Posted on Apr 09, 2007
eagle338
  • 4889 Answers
SOURCE: zanussi fridge freezer frostfree ZX 57/3 W not working
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Hope this helps,
Sai.
Posted on Jun 13, 2008
docjohn174
  • 943 Answers
SOURCE: Amana bottom drawer fridge/freezer combo
hi. thanks for the question . it sounds like you have a compressor problem . wich is under warranty from amana. great news get in touch with amana thanks the appliance doc
Posted on Sep 28, 2008
  • 358 Answers
SOURCE: Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
Posted on May 01, 2009
  • 400 Answers
SOURCE: GE Profile Artica Side by Side Refridgerator isn't cooling.
You say fan seems to be working? it either is or it is not working. If you are getting a reduced airflow in the cabinet, it may indicate that the evaporator coil is iced up and needs to be manually defrosted.
Posted on May 08, 2009
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Kenmore trio freezer and refridgerator not cooling
Sounds like you have a relay switch or igniter not working. If it is less than 6-8 years old, this probably,is the problem.
Feb 10, 2013 | Refrigerators
Fridge light on but fridge warm, freezer still working. zanussi built in fridge freezer 3 year old
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Refrigerators
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Refridgerator isn't keeping cold
its in the freezer when you open yhe door the compressor is in the back take the cover off and see if trhe compressor is running
Apr 03, 2008 | Refrigerators
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge does not cool
lo1972
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
handiman518
Jan 16, 2008 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
