My Technics SL-DV290 stereo has stopped playing dvd/cds, it just says 'no read' when it initially scans dvd/cd prior to play Please help!
  • 1 more comment
  • craig200_3 Jan 08, 2009
    hi, i have the same problem with mine as well, i tried to clean the lens but still no luck, is there a help line where i can send it to get repaired or anywhere where i can buy a replacment dvd changer, please email back to me at craig.nash90@ntlworld.com
  • nyalayngha Jan 25, 2009
    I bought a cd/dvd cleaner from littlewoods and tried to clean my hi fi but whem it tries to read it comes up with NO PLAY
  • Anonymous Apr 06, 2009
    No play
  • 4,234 Answers
This means that the unit can tell that a disc is present, but can not read it. Try opening up the top and cleaning the lens using a cotton swab and alcohol. Let us know if that resolves the problem.
Thanks,
Dan
Posted on Apr 02, 2008
    New Friend:
I have a TENHNICS SL-300 COMPACT DICS CHANGER, THAT KEEP DISPLAYING THERE MESSAGE "ERROR" AND WILL NOT OPERATE TO PLAY A DICS. I HAE FOLLOWED THE INSTRUCTION IN THE TROUBLESHOOTING GUIDE, BUT THE SYSTEM WITH POWER UP BUT WILL NOT PLAY A DICS. AFTER POWEREING UP GET DIRECT TO THE MESSAGE "ERROR." I HAVE HELD DOWN THE STOP BUTTON FOR 4 SECOND SUGGESTED IN THE TROUBLESHOOTING GIDE BUT THE SYSTEM WILL STILL NOT WORK IT WILL JUST GO TO DSICS SLOT 2 - I HAVE CHECKED AND THIER IS NO DICS IN THIS SLOT OR IN THE BACK OF THE SYSTEM.
HOW CAN I FIX THIS PROBLEM???
ROBERT M. GILMORE
Posted on Jan 01, 2014
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
I have a Technics SL-PG480A CD player. It won't play CDs down loaded from i tunes. These CDs will play on another newer Sony. The Technics plays other commercial Cds without problem both before and after...
This player will not play either MP3 or MP4 encoded CdRs. It is a good 18 years old now and such things were unforeseen back in the day. The newer sony may well be MP3 compatible. You could convert MP4 to standard audio types on your pc via any number of software applications.
Dec 23, 2010 | Technics SL-PG480A CD Player
Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Sep 06, 2009 | Technics SC-DV290 System
FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
May 08, 2009 | Technics SC-DV290 System
When Making A CD To Play On My technics SL-PD8 It
If thhis happens quite often , and does not depend on the media, then it is usually a dirty lens problem. The lens is dirty or scratched and sometimes cannot read CD TOC (table of content).
If this happens only on reocrded CDs , try changing the media used. For example if you used +R, try with -R.
If this happens on all media, then try cleaning the lens with a lens cleaner CD or blowing some canned air on the lens.
See: CD and DVD Lens Cleaner...
May 02, 2009 | Technics SL-PD8 5-Disc CD Changer
Technics sl-dv 290
I think your dvd is set to a different region. This might help:
1. Insert disk
2.Wait for 'no play'message
3.Immediately press stop
4.It wi go to chapter review automatically in about 5seconds time u should be able to press play and start the movie
Hope this helps
Miss didi
Nov 01, 2008 | Technics SC-DV290 System
SL-DV290 DVD player error message
sl-dv 290u meu refuza sa functioneze. Knd il aprind se aude un barait in boxe si se stinge. Ce pot face pentru a remedia aceasta problema?
Apr 03, 2008 | Technics SC-DV290 System
Technics sc-dv250
did you buy your system in adifferent region and moved with it to another? I heared something like some DVD players are region-locked. I could be wrong but google about region-lock... try this among others: http://dvd-player-software-review.toptenreviews.com/what-is-dvd-region-lock.html
Pikles
Mar 16, 2008 | Technics SC-DV290 System
Technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Sep 20, 2007 | Technics SC-DV290 System
Won't play cds or dvds
you need a new motor in yr dvd player i had same problem had new motor works now
Aug 04, 2007 | Technics SC-DV290 System
914 people viewed this question
 Grubhead
Grubhead
