Question about Canon PowerShot S1 IS Digital Camera
Flash will not pop up. Camera was returned to Canon but not repaired because warranty had expired. Problem was diagnosed as software, not mechanical-estimate $300.00. Flash did pop up once and operate properly but refuses to do so again. Is there a way to manually deploy it? The rest of the camera works fine.
This also happened to my camera and I am able to pop the flash up manually by flicking it up with the edge of my fingernail. It helps to simultaneously press down on the piece just above the microphone (I think) which is just above the viewfinder. That gives a little leverage.
Posted on May 04, 2008
The internal flash on my canon eos 60d camera won't pop up
On the hot shoe when you fit a flashgun it pushes two tabs down to disengage the pop-up flash some times the tabs don't fully return after flashgun removal
Jan 17, 2016 | Canon EOS 60D Digital Camera
Built in flash dosen't pop up
5 error is a mirror return error.
The reason or this error message is that the mirror not is returning after a shot. To normalize the camera, a second press on the trigger button is necessary. 4. Note that all functions operate perfect, and the mirror slides smooth in its trace.
The 5 error often happens when using 3rd party lenses (Sigma, Tamron, etc.) which cause incompatibility problems. Were you using a non-Canon lens?
Also clean all contacts with a pencil eraser. Do this with your battery contacts as well and try fresh batteries.
Jun 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel T4i 650d flash pops up but does not work.. Camera is 2 months old any suggestions please
I suggest you return the camera back to the shop and get the camera repaired or replaced as it would be still under warranty.
If you try to fix it yourself you may void your warranty.
Feb 22, 2013 | Canon Cameras
Canon d60 - Built-in flash will not pop up
There may be something obstructing it from popping open. Inspect the flash area carefully. You could remove the battery and put it back in to see if it corrects the problem. Also, check the flash settings in the menu to make sure that the flash is set to operate. If all of those fail then take the camera in for warranty repair. If the warranty has expired and nothing else works I would suggest getting an external flash for you camera. You will be amazed how much better your photos come out using an external flash. If you go that route then I would suggest going to a camera shop or department to make sure the flash will work for you before purchasing. If you just want a small flash a little better than the built-in, get the SB400. It's only around $125. The SB600 is much better, but will cost almost twice as much (but I think it's worth it).
They work beautifully in auto, but the SB600 will reach much farther and give you less red eye. Good Luck you have a great camera!
Nov 10, 2009 | Canon PowerShot EOS D60 Digital Camera
THE AF-ASSIST BEAM WORKED THREE TIMES BUT WONT WORK NOW - BOUGHT NEW ONLY 3 MONTHS AGO.
return it for replacement under warranty before it expires. This is not fixable by DIY and you should not attemp to open it as it will void warranty
Sep 13, 2009 | Canon Speedlite 430EX TTL Flash
My Canon Powershot SD880 is emitting smoke.
This appears to be a common problem with Canon SD series cameras and especially common with the SD880. Canon must be aware of the problem, and since they have not recalled the cameras they must think it is not a fire/injury hazard. Distribution of the SD880 was suddenly stopped despite excellent reviews. If enough of us tell Canon we want these cameras fixed or replaced, even if they are out of warranty, maybe they will FixUs!
May 21, 2009 | Canon PowerShot SD880 IS Digital Camera
Canon powershot S5 IS flash made popping noise then quit altogeth
Needs repair, You will need to take it to Canon repair center. Google and find the nearest service centre.
It seems like your flash has really pooped!
Feb 26, 2009 | Canon PowerShot S5 IS Digital Camera
Err 99 when use internal flash
There is a Canon Help line on the Canon web site which will help you. They are excellent
Jan 19, 2009 | Canon EOS 40D Digital Camera
I have a Canon Digital Rebel XTI and the flash pops up but doesn't fire in any mode. Is there something I can do to fix this?
It sounds to me as if the xenon bulb within the built in flash has expired.  It's a quick and easy job for a qualified service engineer to repair this for you.
Dec 11, 2008 | Canon Rebel XT / EOS 350D Digital Camera
XTi 400D flash
It appears that the small hook that holds the flash down is not latching properly and perhaps needs replacement. If your camera is still under warranty, call Canon Customer care. Even if the warranty has just expired (like 1 or 2 months), they generally honor it and get the service done free of cost.
Mar 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
94 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
