Refrigerator is only 50 degrees with temp control on 7
SOURCE: Refrigerator seems to run all the time
Hey Wisper, I had a very similar problem with my Haier. Read all about it here: http://www.fixya.com/support/t180574-freezer_10_deg_fridge_50 I replaced the thermostat ($35 or so, mail ordered) but that didn't do very much. Then I replaced the Evaporator fan ($40 for an OEM part, read the details on my other page) and that did the trick. Feel free to email me if you want more details of what the job involved. I'm @gmail.com and the address is RobCuthbertson
SOURCE: there is water leaking from inside of the
your freezer cabinet need to get all out also the ice machine(if you got one),and open the back wall
there
is a drain hole in the bottom middle of it make sure it is clean, and if
you pure water they go all the way
through the pip to the drain pan
next to the compressor.
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards.
SOURCE: Freezer froze up. Emptied and unplugged, allowed
your thermastat went bad replace thermastat.
SOURCE: Haier Refrigerator RRTW18VABW Freezer works,
Hi!!
Turn unit OFF unit and DISCONNECT POWER CORD from wall outlet.
If equipped, remove the Ice Maker Unit by loosening the fastening screws and disconnect the electrical connector.
To remove the the full-width freezer shelf do the following:
Remove the 4 screws (one on each corner) of the back cover and tilt it forward just enough to unplug the freezer (evaporator) fan, then remove the cover.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
