I'm having problems everytime I try to print it freezes even after I restart the computer.
    Genius:
  • 2,785 Answers
Reload the printer driver. and report your status
Posted on Apr 03, 2008
Win 7 64 bit freeze when starting XiMeta's NDAS NetDisk. I'm using newest version 3.72 from Ximeta website.
I have the same problem. I don't have the right solution but I discovered a workaround.
The problem occurs everytime when I install a windows 7 update.
My work around:
  1. When Windows determines an update I disable the NDAS service with msconfig
  2. The update is installed without the NDAS service operational.
  3. After update I enable the NDAS service with msconfig
  4. I restart my computer. Then it freezes.
  5. After a hard reset, the computer restarts in Safe modus. I restart my computer and my computer works, till the next windows 7 update. Then I start again van 1.
Very suboptimal, but it works.
Anton
Jul 08, 2011 | Ximeta (NDU10200CU)
Everytime i print anything ..this message comes ( this document failed to print ) even though it prints the test page
"this happens where there would be a problem in the installation of the printer program..I may suggest to try to restart first the computer and the printer..then if that did not work try to uninstall the printer program and re-install it again.."
Jul 03, 2011 | Computers & Internet
I am facing printer spooling service not running problem even meny time I restar service auto close.
I had similar experience with the print spooling service crashing everytime I restarted. I discovered there was a pending print job in bullzip pdf printer that refuses to delete. So I uninstalled the pdf printer and restarted the pc. Kindly do the following:
1) Go to your printers and faxes and Check if there are pending jobs that have not yet printed out.
2) If there are pending print jobs, try to cancel them.
3) If they wont delete, try restarting the PC.
4) If after restarting the PC, the print job is still there, try uninstall the printer or delete the printer.
5) Re-install the printer.
Feb 09, 2011 | Computers & Internet
We arent able to fax and when we try to we get a no answer confirmation sheet and everytime we print something from the computer or copy somethng we have to restart the machine cuz it freezes.
try to unplug sockets from from fax board and put it again all that when machine is closen ok be carful and try again and it's works properly if it's not works keep in touch ok
Dec 23, 2010 | Ricoh Aficio 1035 Copier
Just got new acer desktop. Downloaded latest itunes. Transfered all music over to this itunes all 850 ish songs. Everything fine.everytime i try to synch my ipod touch with itunes it synchs maybe 60 - 70...
restore your ipod to original factory settings... unfutunately you will need to use itunes for that, hope it does not freeze... good luck!
Jun 23, 2010 | Apple iTunes
Epson 880 printer will print one document, then computer freezes when I try to print another document. Have to reboot, but the problem repeats
what's your operating system? If your using PC, try to restart your print spooler. try to uninstall and reinstall the driver.
Apr 28, 2010 | Epson Stylus 880 InkJet Color Printer
My computer is continually freezing everytime i restart it. how can i fix it. sometimes it will simply refuse to go through the startup and freeze after the original asus symbol is shown.
Freezing can be bad memory among other problems. Try removing a stick and see if you can boot. If not, swap sticks and try again.
Memory is not that expensive so buy more and try above.
Mar 13, 2010 | Computers & Internet
Not printing
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Aug 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Print Spooler Problem
Try this:
Start the computer in safe mode then delete all the files and the folders in the following two folders: • C:\Windows\System32\Spool\Printers
• C:\Windows\System32\Spool\Drivers\w32x86
Start Registry Editor. To do this, click Start, click Run, type regedit in the Open box, and then click OK
Locate and expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86
View the list of subkeys. There should only be the following subkeys: • Drivers
• Print Processors
delete any other in this list
Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
View the list of subkeys. There should only be the following subkeys for the default print monitors: • BJ Language Monitor
• Local Port
• PJL Language Monitor
• Standard TCP/IP Port
• USB Monitor
delete any other in this list then restart your computer.
Good Luck
May 24, 2008 | HP PhotoSmart C4180 All-in-One Color...
Computer is freezing
If it works in safe mode but not in normal mode, then it is probably a driver issue. I know that you've said that you've updated all of the drivers, but that really is the most common problem. (corruption in the file system.)
that said, click on >start>run and type in "msconfig" (without quotes)
Choose "diagnostic startup", restart your computer and see if it still freezes.
If it does, then it's probably your windows file system that's corrupted.
If it doesn't freeze, go back in to msconfig and turn on things one by one, restart in between, and keep going until you find out what is freezing it.
It may take a while, but that is the SAFEST way I know.
Nov 19, 2007 | VIA P4X266 PE11-L Motherboard
206 people viewed this question
jasbo
jasbo
