Question about Vizio P50HDTV10A 50 in. Plasma HDTV
P50HDM Vizio Popped and went out. Which board fixed yours? Z sustain, or Y sustain, or were both needed?
  • 5 more comments
  • Anonymous Nov 30, 2008
    I had the same thing happen to mine. I took it to a Vizio registered repair center and they said the screen must be bad b/c all the repairs they attempted did not fix the problem. Let me know if you get it fixed. I've had the TV for a year and a half, it's sitting in my basement collecting dust!!
  • Anonymous Feb 08, 2009
    4amp fuse on y board open replaced fuse loud pop and fuse opened again
  • Axle80
    Axle80 Feb 18, 2009
    Well I gave Costco a shot and they wouldn't warranty it because it was a month past. They basically gave me the CS number to Vizio and told me not to let the door hit me on the way out....less than satisfied with the 'concierge service'. The part numbers you recommended are different from the boards in my set, are they interchangeable, is there a newer version of the board that is better to get than another?
  • nuke27 Mar 07, 2009
    axle80 -
    what were your symptoms, as in what exactly happened to your tv?
    i got a pop, then no pic or sound. i dont have a warranty however.
  • Anonymous Apr 18, 2009
    I called up VIZIO today and they told me that the TV was out of warranty. I noticed that LEDs D16 and D17 on my LVDS board do not light up. Does anyone know what the voltages on the Z sustain board are supposed to be?
  • husza May 02, 2009
    What phone number did you call?
  • Anonymous May 06, 2009
    I called Vizio but because I bought the TV used on Craigslist, they said they would not warranty it. They referred me to an authorized repair center. I guess I'm gonna have to try to swap the boards myself.
    Scholar:
  • 73 Answers
Hey guess what?! After Costco shafted me good, told me to get lost, and slammed the concierge phone down, I called Vizio. THIS TV HAS A LIFETIME WARRANTY ON IT NOW!! They will fix/replace it at their expense! After a 5 minute call to their customer service they arranged the repair order. Vizio knows that this set is a lemon and they are actually owning up to it. The gentleman told me that this set now carries a Lifetime warranty on parts (to exclude a shattered screen of course) and labor! The repairman is going to come this way in the next week or so and I'll update you on what he says. So to all out there with problems on this set: CALL VIZIO AND GET READY FOR A BREATH OF FRESH AIR!
Posted on Mar 04, 2009
  • 2 more comments
  • Axle80
    Axle80 Mar 11, 2009
    My tv got the pop of death. No sound no picture. The led would come on and flash orange and green 8 times then shut itself off. The vizio guys came today and found the exact same thing I did. After replacing EVERY board in the set they were able to only get a weird vertical purple stripe to appear. So after a call in to the HQ I will be getting a brand spankin new set by the end of the week. So long story short. ********CALL VIZIO FIRST! THEY WARRANTY THIS TV FOR LIFE******** no joke, they are replacing this set. Its nice to see a company stand behind their products. Sure wish S0NY would do it, when there stuff has obvious defects they just ask you to bend over and make use of the broom handle.
  • Axle80
    Axle80 Mar 11, 2009
    Something to note with this TV. I am NOT the original owner, I never registered the TV nor do I have any paperwork to back anything up. And it didn't matter one bit to the Vizio CS guy. He told me frankly that it didn't matter who ended up with the set, That particular model was under warranty with or without documentation. I think I have found a new favorite brand.
  • Axle80
    Axle80 Mar 19, 2009
    Just as suspected, the repairman came and did his thing. It was actually pretty funny to have an old fat guy try to explain to me in terms that a 16 year old girl would understand, "your tv, sir, has large green circuit boards in it, they use electricity to generate signals displayed on the screen, each one has a function like blocks making a tower. If one stops then the tower might fall or in other words your tv stops working, I think your problem is in a large board here called the Y board. It...." I stop him short and say " I've swapped the Ysus and the Xsus without success, the buffers all are running correctly, all voltages on the PSB came out correctly or within 2 volts, did vizio send you with a logic main to replace the old one? Let me save you some time, it can't be fixed."
    The guy offered me a job on the spot. I laughed and thanked him anyway. He phoned in the result and a week later I got a call from the Delivery guru, he's going to show up next week with a brand spankin' new set. I will repost again with the model number of the new TV.
  • Axle80
    Axle80 Apr 15, 2009
    March 25th, they replaced it with a VP50HDTVA10. Looks nearly the same with some added styling. Appears brand new. It certainly doesn't look or perform like a refurbished model. It actually came in a mfg box which they used to repack the old lemon. Good luck to everyone. Post if you get a different result from Vizio. I'd like to know how everyone else's experiences are turning out.
    Problem Solver:
  • 8 Answers
Replace the Z Sustainer Board, Part # 6871QZH044B and replace the Y Sustainter Board, Part # 6871QYH039B at the same time. If you replace one and not the other the bad one will end up shorting the good one and you’ll lose your picture within a week. You can do this work yourself by unplugging the unit and placing it face down on carpet (put down a soft blanket to protect the screen) and unscrewing the back of the unit (a power screw driver works great for this job because there are a few screws involved). The cheapest place to buy these two parts are: www.discount-merchant.com , or www.avextra.net, or www.ebay.com
Posted on Apr 14, 2008
  • Bob Bright Nov 06, 2008
    Oops, I forgot to mention the most important part of the P50HDM Pop of Death. If you purchased that unit at Costco then call their Concierge Service at (866) 861-0450 for Service and DON'T PURCHASE ANY BOARDS let them come fix the problem. Costco is aware of the POP on the P50HDM and is committed to making it good even if the TV is 2 or 3 years out of warranty. Costco probably took in the shorts with this model but they stand behind their electronics. However, if you let your Costco membership lapse since you purchased the TV then they won't provide that service, it's only for members with active memberships. In the end they will eventually give you a brand new Vizio 50" TV from their stock and put your damaged P50HDM in the box of the new Vizio 50" 720p Plasma (so you'll drive home with the TV but no box) and send the damaged one back to Vizio. But the best thing is that the new 50" Vizio 720p Plasmas have an estimated life of 50,000 hours where as the P50HDM's only had an estimated life of 10,000 hours (the difference in hours sure makes it appear that Vizio knew about the problem when they manufactured the unit). So the replacement TV should last for many more years than the P50HDM.
    Problem Solver:
Vizio wont stand behind tv unless you bought from major retailer. I've tried w/ 2 ....p50hdm's
Posted on Feb 12, 2010
    New Friend:
Just so you know, VIZIO is no longer standing behind its "lifetime warranty". Someone at "corporate" headquarters made the decision to end the warranty for this issue May 2013. You'll be given the number of a servicing technical contractor who is more than happy to come to your home and charge $500 plus to address your concerns.
Posted on Dec 28, 2013
  • Richard Hayes
    Richard Hayes Dec 28, 2013
I called Vizio prior to seeing this posting and was sent to a service company that wanted $525.00 to fix the t.v. I was searching the web trying find what was wrong and fix it myself.. Then I read your posting called Vizio back and told them I heard the the P50HDM had a lifetime warranty.. I was asked if I heard a POP.. I told them yes and was forwarded to another person who set up a tech to come out and service the t.v. (free of charge).. I am glad I found this information.. They say they are aware of the problem with the t.v. and will replace the bad components..
Posted on Apr 27, 2009
  • Richard Hayes
    Problem Solver:
  • 14 Answers
You can opt to repair the Y board by replace the following components: ic12, ic4, hs1, x1, ic18.
LG has also updated the large silver IC modules but it's not necessary.
Posted on Feb 22, 2009
I have a lg42pc3d plasma tv. its about 5 yrs old has worked just fine till last night the picture went out. Sound works but no picture. Have been on line and the consensus seems to be the x and/or z...
Yes usually the x and y sustain boards go. Not always with both fail, but they communicate with eachother...this is why replacing both is "good practice." You can check shopjimmy, ebay and encompass parts for parts online. Just order new replacements...you can tell a bad board usually by burn marks, popped capacitors, etc.
Jul 12, 2011 | LG 42PC3D 42 in. Plasma Television
I have a 42" LG
It can't be fix by replacing the fuse alone because the IC's and other parts are already faulty. You need to replaced the entire Y-sustain board. Try this LINK or obtain it from your local LG Service Centers.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jul 05, 2011 | LG 42PX5D 42 in. Plasma HDTV
I have a LG 42PC3D. For quite a few months it had multiple "red dotting" around the left side and bottom left that only was bothersome when the 'scene' was dark...it did not affect it when the...
It sounds like you may have a Y sustain board failure. If you open the set, the large board to your left is the Y sustain. Most of them have part numbers on the board and you can order it from a LG supplier or LG them selves. 1800-243-0000
I hope this helps
Skyassoc
Dec 11, 2010 | LG 42PC3D 42 in. Plasma Television
LG 50PC3D very loud pop, screen went 95% black and of course still have sound. does this sound familiar? michael
check the capacators on the main power board if they are not popped more than likely it is either the z or y sustain boards
Feb 28, 2010 | LG 50PC3D 50 in. Plasma Television
Heard a pop and the picture went out
Usually a pop means the an capacitor has failed. You will have to open up the tv to find which and why it has failed.
Feb 14, 2010 | LG 42PC3DC 42 in. Plasma HDTV
My zenith plasma tv popped real loudlike a car backfiring and then the tv picture went black. power on green light wil turn on but it automatically cuts itself back off to the red light
There's an over current fault in the power supply or the Y-sustain convergence board. The loud pop was either a capacitor or pico-fuse breaking from excessive current overload. Sounds like 2 or 3 mosfets have shorted at the gate ends. Plasma TV's always have this problem because they generate too much heat and the components cant take the load conditions. Make your next TV an LCD...
To fix this problem have your local repair shop do it for you.....
any questions please ask.....
Jan 20, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
HDTV was ruuning & then popped. Then nothing
This is a common problem on these plasma TV's. The problem resides inthe high voltage boards known as the X and Y Sustain boards.. You canpurchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Jul 05, 2009 | Zenith Z42PX2D Television
Zenith zsus pop
Hello to all! Some of the time with LG type Y & Z sustain boards you must replace both the boards in order to completely the repair or but not always. Please feel free to message or call me if you need more help with your Zenith plasma TV. 1-503-432-9904 / pleasefixitdave@yahoo.com Ask for Dave! If you are reading this post and you need help with a plasma or LCD type TV give me a call!
Dec 20, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
1,895 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
