Question about Power Acoustik Area 820x2 Car Audio Amplifier
Area 51 I hooked my amp up the way it shows on the back and only the lights come on no sound
    Novelist:
  • 100 Answers
Well you could have a couple of problems... First, if you have a separate, non-fader output on your radio, make sure the volume on that is turned up. Also check the gain on the amplifier to make sure that is at a reasonable level, usually 3/4 of the way up. Check to make sure you have good connections and wires going from the amp to the speakers. Also make sure that the RCA cables you are using are good, I have ran RCA cables, to find out later that they got pinched in the reassembly of my car . A way to test this is get a set of RCA cables and run them directly from the back of the Radio to the amp without hiding them. I hope I can help.
-Andrew Hawkins
Posted on Apr 03, 2008
SOURCE:
My GE Monogram Wine Cooler ZDWR24OP does not cool properly. I have the temp set at 51 and it has steadily gone up to 56, 57, now 59. There is some frost on the upper back area inside. I turned it o
Sounds like it is low on refrigerant or not pumping. Either would require a qualified service tech and the repair costs, depending on the price of the cooler, might possibly exceed what you'd want to spend.
Sep 12, 2014 | Refrigerators
1997 gmc jimmy starter motor not turning
You need a better battery. When you hook the amp meter and read 0.3 the ECM needs to sleep
Jan 05, 2012 | 1997 GMC Jimmy
I've got a Dell Alienware Area-51 Gaming Desktop Computer (Intel Core i7 930 QC 1TERABYTE/12GB) (DPPCPW11) PC Desktop, I've had it for about a month now. I hardly ever turn it on and now for some...
Yep sounds like a bad PSU. There should be a warranty on this thing so I would call Dell and tell them the problem and they should be able to get the problem fixed for ya, the only thing is that you may have to ship it to them cause I don't think they'll take your word for it. But I would definitely call Dell at least you'll know your options then.
Dec 27, 2010 | Dell Alienware Area-51 Gaming Desktop...
When turned on, the control display shows " HP>>>>> " and stops going up. No sounds,no fan, but display remains on. I tried holding < and cancel...
This problem ussualy caused by a problem in the formatter (Mainboard) . There is nothing you can do to recover it. If the printer is still under warranty you will need to call HP (1 800 334 51 44) or take the printer to an athorized warranty depot in your area. This link will help.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Nov 04, 2010 | HP Laserjet M2727nf Multifunction Printer
Guitar amp shows power but has no sound, could it be a blown fuse
Nine times out of ten, any problem with an amp having no sound coming out, it's a wiring issue. Make sure all of the wires internal to the amp are propely hooked up. Also, try switching out the quarter inch cord you are using from your guitar to your amp. Could be a bad cable. Unless you have blown the speaker completely, something is loose or not hooked up properly.
Feb 27, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
No sound from amp
THIS IS AN EASY FIX. DISCONNECT THE POWER WIRE FROM BATTERY. REMOVE THE GROUND WIRE FROM THE CARS BODY. SAND ALL THE PAINT AWAY FROM THAT AREA. WIPE IT CLEAN WITH A DRY CLOTH AND HOOK THE GROUND BACK UP. THEN RECONNECT THE POWER WIRE AND THAT SHOULD FIX IT. IF NOT THEN TURN DOWN UR GAIN CAUSE THE AMP IS OVER HEATING
Feb 19, 2009 | Pioneer GM-5200T Car Audio Amplifier
CL-51 Braxial component
ok well do u have a amp hooked up on the speaker and if not u could have dust in there or it could be a blown voice coil in the woofer part it self best way to check is to take a cotton swab u use in ur ear andgo along the coil part the speaker u no the brownish looks like ornge wires sum thing like that and do it very gently swab around the coil let me no if that helps
Apr 05, 2008 | Cdt Audio CL-51 Car Component System
How to hook up surround sound
Check in the TV audio menu adjustments to activate the audio going out to the external speakers.
Hope it works.
Feb 08, 2008 | Hitachi 51F510 51" Rear Projection...
No Sound, No Picture
loose connection inside i would check the convergence amp area.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Sep 23, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Power Acoustik Area 820x2 Car Audio Amplifier Logo
125 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
