Can not get on line
I have a d link wireless modem and i can not get online throu a cable. i ahave conected the router on the modem, the wireless working but the router does not allow my desktopo to get online throu the wire
    Sergeant:
    Champion:
  • 427 Answers
1. Make sure the ethernet cable going from the modem is going into the port on the router labeled "internet." Next, make sure the ethernet cable that is plugged into your desktop is going into the port labeled either 1,2,3,or4.
2. If it is in port 1, or any other port, make sure you try all of the number ports.(1,2,3,4)
Posted on Apr 03, 2008
SOURCE:
I can't install the router from the CD to my computer, I follow the steps, but when it says please wait reconizeing your router, it want reconize it says check the ethernet conections.
You don't need to install a wireless router. unplug your modem, connect the ethernet cable from your modem to the port on your router labeled internet or WAN, and then plug in the modem and router. Connect your computer to the network and you should be online.
Mar 04, 2011 | Linksys WRT160N Wireless Router
WIRELESS ROUTER WILL NOT CONECT TO NET
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Oct 03, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
How do i hook it up period
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
then you need to connect the computer to the router and the modem to the router.
Click Here for step by step by instructions
May 21, 2010 | D-Link DI 514 Wireless Router (DI-514)
I have a range booster g router D-link wbr-2310 and do i have to conect to the box from comcast or the conection on the wall and i put the disk an alat of archie show up and i dontknow what to put please...
I assme you have a DSL or cable modem from Comcast and this is connected to the wall. The LAN cable from this modem should now be connected to the WAN/Internet port on the DLink wireless router.
To secure your wireless network please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Mar 21, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Belkin router
The router normally goes between the Cable Modem (or DSL line) and the computer. Use a CAT-5 cable to connect modem to the WAN input connector on your router (the connector labelled "Internet), then another CAT-5 cable goes between any of the ports and your computer. Using your web browser, go to 192.168.1.1 and continue with the router setup, choose an SSID (what you name your network), followed by Wireless Security if your router supports wireless as well. I like WPA-PSK[TKIP] for its simplicity. Anyway, the router is now useaqble by other computers!
Nov 11, 2009 | Computers & Internet
My router wont configure
Plug in the laptop to the router and the router to the modem. Power cycle the modem. Turn on power to the router. Copen a command prompt on the laptop and type 'ipconfig /all' and press Enter. Look for your IP address (should have been assigned by the router and should look like 192.168.1.x). Also look for the default gateway. It will probably be 192.168.1.1. If that is the case, you should be able to use your web browser to connect to the router to check its configuration and the WAN status by typing in the address 'http://192.168.1.1' (or whatever was displayed for the default gateway previously.
Apr 11, 2009 | Dell Inspiron 4150 Notebook
How to conect a wireless router to a regular modem
If your modem/router has a USB connectivity, you can connect it via USB. Else you will have to buy an Ethernet PCI Card, which wont cost you much.
I hope this solves your problem. Good Luck ! Kindly Accept my Solution.
Regards, Arjun
Apr 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
D-link router setup says 1 computer must be connected and online
What this means is your D-Link router must be cable connected the cable modem and your pc cable connected to the router. I don't believe you can just plug your pc into the router alone.
Mar 30, 2009 | Computers & Internet
How do I connect a MaxG wireless router into a SmartAX MT880 DSL modem
  • Connect cable from router to computer ...
  • Connect cable from router (internet port) to the modem ....
  • U will be able to go online ....
  • And after it is done ...u can do the wireless settings ....
  • then connect to network and u will be perfectly able to go online ....
Oct 24, 2008 | U.S. Robotics (USR8054) Router
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at [email protected]
Feb 03, 2008 | 2wire (1000-400108-001) Router
Open Questions:
Aol support email 18OO-8O3[[1O69]] number*v*~u.s.a rrdf Usa AOL USA phone number is ranked #2 out of 2 because 7,728 AOL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO::8O31069 is to reach t he AOL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AOL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL USA Calling AOL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL USA's phone numbers against each other. Contacting AOL USA in General While I8OO8O31O69 is AOL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL USA.
Oct 19, 2019 | AOL Computers & Internet
Aol desktop gold tech support phone18OO-8O3[[1O69]] number*v*~u.s.a rrdf Usa AOL USA phone number is ranked #2 out of 2 because 7,728 AOL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO::8O31069 is to reach t he AOL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AOL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL USA Calling AOL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL USA's phone numbers against each other. Contacting AOL USA in General While I8OO8O31O69 is AOL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL USA.
Phone number 18OO-8O3[[1O69 for aol customer support + number*v*~u.s.a ygh Usa AOL USA phone number is ranked #2 out of 2 because 7,728 AOL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO::8O31069 is to reach t he AOL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AOL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL USA Calling AOL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL USA's phone numbers against each other. Contacting AOL USA in General While I8OO8O31O69 is AOL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL USA.
Computers & Internet Logo
53 people viewed this question
Ekse
Alun Cox
