Question about Onkyo HT-S790S System
Sound, but no video
Our system was working for nearly a year. Then on evening after watching our cable tv through the onkyo theater system and shutting all components down as usual, the video quit working. The next morning upon start up, we could hear the cable tv through the speakers, but the tv showed the message "weak signal". We checked all wiring connections. All was intact. We tested the cable box. It works normally when connected directly to the tv. It just no longer works through the onkyo for video feed. We checked the manual for troubleshooting. None offered for video problems. We called. The tech could not solve the problem. Any ideas before we bring it in for service? I have seen the same problem in posts on other onkyo theater systems in this forum.
  • 4,234 Answers
The video is switched by a single chip similar to the one that switches the audio signals. It is possible that the chip is defective. Even as a shotgun approach, changing the chip shouldn't be more than $15-$25 for the part.
Keep us posted.
Posted on Apr 02, 2008
When we watch a tv there is no sound my home theater
Hi Violeta, sorry for the delay in responding. When you say "when we watch TV there is no sound", are you using the TV's built in applications? Please email me directly at, Thanks, JT
Mar 09, 2015 | Onkyo Ht-r340 A/V Receiver
Sound from Onkyo CD player well and fine. Then connected the Samsung DVD HT-Z310 to Video3 (L/R audio in, V-in from L/R Audio out and V-out of Samsung) but no sound or nor video on TV? Tried to fix it...
What am I missing here?
There are a lot of models mentioned in this post. What are WE discussing?
* A Samsung HT-Z310 is a Home Theater System.
* An Onkyo TX-DS777 is higher-end AV Receiver that DOES have a Video 3 input which accepts composite video and analog audio.
* An Onkyo CD player is irrelevant to the TV sound in any scenario.
* Unnamed TV.
I don't see any path in your narrative that would carry audio TO the TV. Is there an unmentioned HDMI cable in here somewhere? I see no other audio outputs on the HTZ.
Are you running the HT-Z310 through an Onkyo receiver to somewhere (?) else?
Register and download the manual for free at
The fewer hops and inteconnects a given signal experiences between its source and your senses, the better. I always run the BEST video from any source to the TV first; the best Audio to the BEST audio electronics. If that helps.
Apr 03, 2011 | Onkyo TX-DS777
How do I connect my TV to play through the surround sound?
What kind of tv?
I HOOK cable to MY DVD-R which has a Cable IN jack then use audio out to my MY RECEIVER which repoduces the TV & audio signal, I then set my TV to the S-video mode to watch.
Aug 21, 2010 | Onkyo HT-S790S System
I have an Onkyo HT-S6100 home theater not sending picture to TV.
I just fixed mine with the same problem. Apparently, the HT-R667 and 606 receiver that comes with 6100 has a problem with the HDMI board. Onkyo wanted $500 dollars to fix it, costed me $16. Here's how to fix it.
and the youtube vid:
Good Luck!
Apr 04, 2010 | Onkyo TX-SR605 Receiver
Why cant I supply my onkyo surround sound system
You need to assign the HDMI input(s) to the functions they represent, using the Front Panel Tuning/Preset control...
If you connect a video component to an HDMI input, you must assign that HDMI Input to an input selector in Setup.
For example, you could assign the “DVD” setting to “IN1”, and assign the
“CBL/SAT” setting to “IN2”.
Likewise if you use digital audio inputs...
Assigning the Digital Input
If there’s no sound, press the [DIGITAL INPUT] button repeatedly until sound is heard. The digital input is now properly assigned.
If you connect your DVD player to the AV receiver’s COAXIAL 1 DIGITAL IN, and your cable/satellite receiver
to the COAXIAL 2 DIGITAL IN, as shown, it’s not necessary
to assign the digital input.
Feb 12, 2010 | Onkyo HT-S5100 Theater System
I, have a LHT874 theater system no sound when watching tv
HI, check if you have to turn up the outputs on your tv or even switch them on,also make sure you are useing the audio outs and not an input then set your system to the same input the cables are pluged into and set sound to prologic 2.
Hope this helps.
Feb 24, 2009 | LG LHT854 Theater System
No audio from my PS3 through the Onkyo 5100 7.1
if you are using an HDMI cable dont expect sound to come out (even thought HDMI carries both audio and video) the onkyo HT-s5100's Receiver is the HT-r560. the 500 models of the onkyo receiver does not allow HDMI to carry both audio and video. it only allows the video signal to pass to the receiver.
if youre using optical for audio w/c is what you need then these are the steps you need to follow.
*first make sure that the optical connections are ok at the back of the receiver.
*make sure that your DIGITAL INPUT is set to either OPT1 or OPT2 whichever optical input you used to connect the optical cable.
*then go to your PS# settings : go to sound settings / audio moutput settings/ select digital out (optical).
then enjoy.....ü
Jan 27, 2009 | Onkyo HT-S5100 Theater System
Unable to get home theater sound on cable tv mode
I had this problem on my own tv and it nearly drove me mad, in tv menu under sound submenu their is a setting called spdif mode, there are choices in this mode that can be made, My current tv has Auto, off and pcm. some tv's have more choices. Try playing with these settings and its possible you can get it to work with cable, your cable signal probably uses a different sound format to the blueray/dvd player. note if this works the sound might not work when you go back to blueray/dvd player so note the setting before you change it in case you need to go back to it when you change over viewing choices. good luck.
Aug 17, 2017 | Panasonic Home Theater System System
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
Onkyo HT-S790S System Logo
95 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
