Question about Kenmore 75944 Gas Dryer
Kenmore dryer 110.76732500 problem
The blower wheel needs to be replaced on my gas dryer. 1/4 of the wheel broke off due to a drill bit falling down the lint trap. I have the replacement wheel but cannot get the old wheel off. I tried holding the front of the engine shaft with a wrench while moving the wheel clockwise from behind the dryer. It wont budge.
  • 63 Answers
I would take a hammer and hit it hard break it off I have done this a hundred times at my shop then you can put new blade on with ease
Posted on Jun 09, 2008
Kenmore gas dryer model 110 775 42600 won't heat what is wrong
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Jul 04, 2014 | Kenmore 500 6952 Dryer
Dryer only works on 1 setting and is not heating
If your dryer is not heating assuming is a gas dryer. It could be due to The electrical fuse igniter is not working or no gas is going in. Need to remove the front bottom cover and check that the fuse is igniting when you turn on the dryer. You should hear a clicking noise just before the igniter turns red ( glowing) to receive the gas and create the flame to then produce the heat. If you are not able to see the fuse/igniter conduct this process, you might need to replace it.
Nov 16, 2013 | Kenmore Dryers
Drill bit does not stay gripped, chuckless drill
On this particular tool, you can't really tighten the bit in the anvil like a bit in a drill chuck. The bit is free floating but held in place by a small steel ball. The steel ball is held in place by the sleeve that slides up and down to release the ball so the bits can be changed. The sleeve is held down by a spring. Bits falling out can be caused by: Using bits without the groove in the bottom of them for the ball to catch in, dirt in the bottom of the anvil so the bit can't seat properly, the ball is missing or stuck, the spring is broke or binding, or the sleeve is bent or too dirty to slide up and down freely. Use compressed air to clean the anvil well and WD40 to clean and lube it further. If bits still fall out you'll have to take it apart and see if the ball, spring or sleeve need to be replaced.
Jan 13, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Small toy accidently fell down dryer vent. What to do? Afraid to turn dryer on. Help
To get to where the toy fell on this unit is a little involved. Unplug unit. take out the lint filter and gently turn the machine upside down hoping the object will fall out if not you will need to take the back off the unit and loosen or remove the blower chute to get at the blower wheel and your missplaced object
Good luck...
Aug 10, 2010 | KitchenAid KGYS700LQ Gas Dryer
Kenmore 110.77741600 Gas dryer- Klunking..Now dead then dead...
belt may have broke or something in the blower housing.
Oct 09, 2009 | Kenmore 63942 Dryer
Dryer shuts off before cycle is over. May or may
motor will need to be replaced you mite want to get a blower wheel at the same time they sometimes lock together and will have to be broke off
Sep 30, 2009 | Kenmore Dryers
Noisy dryer Kenmore Elite 70892 (gas-LP)..
OK, Kenmore,.... I don't work on many of them, but,....
Disconnect power. You have to lift the top to gain access to the screws near the top which hold the front panel to the sides. If it has a top lint filter, you will most likely have to remove the screws holding that to the top, then use a putty knife to release the spring clips at the top of the front panel. Sounds like the blower wheel is spinning freely on the motor shaft, requiring replacement of blower wheel.
Sep 06, 2008 | Dryers
Squeeking noise
Here's a possible troubleshooting fix I just sent to someone else that quite possibly has the same problem you have there now.
Hope it helps you out as well, as it is a bit long, but I'll post the whole reply I sent them and you can use whatever parts of it that will work for you.
My name is Frank...
Regarding your possibly broken dryer.
I'm hoping that this info below helps you out even though I know I won't be able to repair/fix your dryer myself personally. Reason why - I'll explain further down.
I've repaired a few gas dryers & washing machines as well in my time. I can honestly say that I'm as close to being an expert as they come - esp when it comes to making repairs on existing dryer parts that can no longer be purchased as they are either obsolete, or way over-priced.
This is what I do for a semi-retired hobby, and sideline self-employed FIX-IT business. Named appropriately - FRANK'S FIX-IT SHOP. It's only an online fix it at present. Keeps me busy instead of being bored to death.
Electric clothes dryers are typically made the same as gas dryers - as to the mechanical drum part. Only thing different in a gas unit is the 110VAC electrical igniter or element, and the gas delivery system that provides the drying heat to the dryer itself.
All else is basically the same...
In an electric clothes dryer all the power comes from the 220VAC source as to the heating element, etc. The mechanical parts are typically the same as that of a gas dryer.
Having said this - the problem with your dryer can only have one of possibly 2 things wrong with it - seeings it's no doubt 220VAC totally electric, unless you actually have gas where you are there, which is rare in Florida these days!
If after you start the drying cycle you quickly open the dryer door, and you notice the drum is actually rotating - until there is the loss of electric power via a safety door switch that kills electric power to the drum motor activity - then there is NOT a problem with a broken drum belt.
If your dryer is older then say 10-15 years, and you really use it alot - then maybe there's a possibility of a broken drum belt (cost is around $10-15 for a new belt part depending on model - usually - and that does not include labor to install it).
Usually you'll hear the motor whining, but no drum 'noise' or movement. Dead giveaway as to a broken belt.
I had replaced 2 belts and 1 IDLER wheel on my own 30+ year old gas Kenmore dryer before selling it, and then picked up a more recent newer model GE washer & gas dryer that someone was just giving away for free. My 30+ year old Kenmore washer had just died on me at the same time is why I upgraded. Can't pass up a great freebie deal like that everyday! Never had to fix anything on my Kenmore washer during the time I owned it - it was GREAT!! I miss it dearly now.....
Though they were both newer GE models I really don't care for GE anything, as I think they are poorly built, as well as is their refrigerator brands as well.
Don't buy GE anything if you don't have to!! You heard it here from me and I know. My GE washer already broke a belt not even being 8-9 years old, and it was hell to replace, and never worked right afterwords as for the water pump part. Very POOR design! Oh well...
The gas dryer works fine, but the lint collector is not anywhere as good as my old Kenmore was. Poor design in my opinion.
I'm looking for another Kenmore or Whirlpool (set) model now, as they are the best. Kenmores are made by Whirlpool btw, just in case you didn't know that. The best in the business!
As to your other possible noise scenario -
The only other weird noise scenario you'll experience if it's a Kenmore dryer is when the drum "spring loaded track IDLER wheel" goes bad. This drum IDLER wheel is located under the drum itself at the back part of the drum and rides in a groove in the drum itself. It also helps to stabilize and counter-balance the drive belt-loaded turning drum that rides on this drum IDLER wheel as it turns. If your dryer does have the rear drum IDLER wheel system, then it just depends on the make and model. Kenmores & Whirlpools are designed this way. Very good design I might add!!
Some, or all GE dryer models may have a rear drum centering bearing assy instead - and in addition to - a front (Support, 3 glide front drum bearing part# 2359 & a Drum front slide bearing part# 2305 times 3 needed). If this/these front support/slide bearing part(s) goes bad usually the "felt duct" will need to be replaced as well. It not only helps to seal and quiet the drum that runs on the Support part, but it also helps to keep clothes from getting in-between the Support C part and helps prevent clothes from getting damaged. If those (3) friction sliders wear out or fall out, and take out or damage the "felt duct" as well, then the noise will be horrendously LOUD.
The front part of the GE drum models usually rides on a separate front panel support assy which can be made of a plastic C shaped device with anti-friction pad strips to help in frictionless rotation of the drum. A cheap but pretty effective design that does away with a front IDLER wheel, or pair of IDLER wheels as it were at the front of the dryer's frame which houses the door assy as well.
Though my Kenmore replacement drum IDLER wheel only cost me around $17 many years ago I see they now are anywhere in the $30+ range. Ouch! If it's the GE rear bearing assy that has gone bad - another Ouch as that part runs around $50+. Just depends on where you are and parts availability.
Most Kenmore/Whirlpool model dryers with the rear spring loaded drum IDLER wheel design do not have a ball bearing design, but rather have a typical cheaper brass bushing design instead, and when the grease lubricant dries out or they become dirty from picking up dirt in the air such as lint from the drum, etc then they begin to SQUEAL or WHINE very loudly.
The longer this goes on like this the hotter the drum IDLER track wheel gets until it melts the "typically" molded plastic housing, and then it really makes a lot of noise, and could actually lend to the drum belt breaking - as due from the added friction & stress from the binding wheel. It can also damage the front "felt duct" material as well. I had to repair mine as best I could as they had n factory replacement part that I knew off.
The only other mechanical parts that could possibly make any squealing type noise would be the electric belt drive motor or the heat blower motor being gas or electric. If the heat blower motor uses a cheaper brass sleeve shaft bushing bearing that would be rare, but could be a noise source as well. The belt drive motor rarely rarely would ever go bad!!
I hope this info helps to narrow down your problem if you are not able to at least open the top up to inspect the dryer yourself. Always unplug the 110VAC power before opening any cover or panel part up though!
That will not only prevent any electrical shock hazard, but will also keep the gas from turning on by mistake - as by solenoid design - if your dryer is gas.
I suspect this is what's wrong with your dryer.
Again - I hope the info helps you out...
Best regards,
Feb 09, 2008 | GE DBXR463GB Gas Dryer
An Old Gas Kenmore 7870701
Michael, here are a few things to check. Can you turn the drum by hand? If not you may have something in the blower wheel binding the motor. You can acess the blower by removing the back panel and removing the two screws under the vent screen on top. Once the back panel is removed the blower wheel will be behind the vent. Three or four screws and it's off. If the blower wheel is ok, it may be the motor itself going bad. Have someone hold the door switch down and while pressing start, give the drum a turn. If it starts running, it's probably a bad motor. Other things to look for is bad rollers. If they are bound up it may prevent the dryer from starting. Check these things out back.
Jan 03, 2007 | Kenmore 72602 Gas Dryer
Kenmore 75944 Gas Dryer Logo
105 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
