Question about InFocus LP70+ Multimedia Projector
Where can I buy a fan for a Infocus LP70? - InFocus LP70+ Multimedia Projector
  • 563 Answers
Hi there
Best would be to search on the net for your nearest dealer , they will surely help you out
Posted on Apr 03, 2008
  • 74 Answers
SOURCE: InFocus LP70
Have you tried another lamp? Sometimes thats your problem, but I've seen a several occasions that the a defective power supply causes this symptom. Do you see an image flicker before the projector shutsdown? I do have some spare parts for this projector.
I'm on Ebay - gtitubro if you want to contact me through there.
Posted on Sep 19, 2009
projdoc
  • 2237 Answers
SOURCE: Infocus LP70 dropped and now
try pulling the outer ring out a little while twisting it (you won't break it). then try the inner ring. if it wiggles, you need to take it apart- and that's not a pretty job.
Posted on Jun 05, 2009
projdoc
  • 2237 Answers
SOURCE: pile of ##@!#@ infocus lp70 green light wont come on. should i smash it??
if the fans aren't running, it's the power supply. if the amber is on and the button's won't turn it on, there is an obstruction under the button panel. if all turns on but the lamp and you don't hear a high=pitched whir, it's the colorwheel. if you do, it's the ballast.
Posted on Sep 03, 2009
SOURCE: InFocus LP70 keeps shutting off
I solved my issue with just simply upgrading the Frimware. Which can be downloaded from infocus website.
Posted on Dec 24, 2009
  • 167 Answers
SOURCE: InFocus LP70 color problem
No it's not the color wheel. If the color wheel stalls the lamp will shut off immediately which is a built in protection mechanism. On the LP70 and 70+ there is a multi pin connector inside located at the rear lower left of the projector. This connector connects the main board to the DLP engine electronics. This connector is horizontal and approx 2 1/4" wide and 1/4" thick and about 100 pins. I have seen this connector not seated completely and many various video artifacts occur (even the one you describe) If you or someone you know is electro-mechanically savvy it's not difficult to open the projector and make sure this connector is seated properly.
You will need a TORX T8 screw driver.
Cheers
Posted on Jan 16, 2010
My LP70 INfocus projector fell then said one fan was not working, will turn off in a minute, and it did, now how do I fix the fan, get a fan part where and how? How much do repairs liek this cost? how...
Hello
Cooling fans have of different size and voltage ratings. The exact size is more important. You must have the damaged fan with you when you go to buy a new one. Its seating screw space, height, voltage ratings etc should be compared, and must be exact the same, otherwise the system main system control IC won't recogonise the replaced fan.
Actually this is a skilled work. If you have all the tools to open the projector, and have confidnce, go forward. Otherwise, get it repaired by any experienced service technician. OK.
Nov 22, 2011 | InFocus LP70+ Multimedia Projector
Process to upgrade firmware for InFocus lp70 ... can some describe this for me please? I've got the firmware downloaded, but my PC does not see the projector .. Help!! I also can not find the USB drivers...
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Apr 27, 2011 | InFocus LP70+ Multimedia Projector
Light does not come on, fan is working and green light at top keeps blinking off and on on a LP70 infocus projector
if you hear a high-pitched whir, the problem is either the ballast or the lamp. if you don't, it's the colorwheel. you could try to get the parts from an infocus service center or send it in to them for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 22, 2009 | InFocus LP70+ Multimedia Projector
LP70 Infocus Projector light will not start up
if you don't hear a high-pitched whir, the colorwheel needs to be replaced. if you do, it's either the lamp or ballast. if the lamp is new, replace the ballast. you can get the parts if you want to do it yourself, or you'll have to send it in. either way, try av solutions in ny. they are an infocus service center and they're really good. www.avsolutionsny.com
if the fans go off imediately too, it's the power supply. if the fans stay on, it's either the lamop, ballast, or colorwheel. either way, you may need to send it in to an infocus service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 14, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
LP70 lamp will cycle on and off in 3 min. intervals.
go into the menu and check the lamp hours. if it's over 2000, you need to replace the lamp. if it isn't, the power supply and/or ballast is starting to fail.
Jul 06, 2009 | InFocus LP70+ Multimedia Projector
Pile of ##@!#@ infocus lp70 green light wont come on. should i smash it??
Dec 20, 2007 | InFocus LP70+ Multimedia Projector
Lp70 projector Error message about Fans
I had a similar problem with an LP70. my fan was sticking.
So I opened bottom cover and pulled out fan cage, there are 2 fans.
you must know which fan not running.
If you found bad one remove paper label(yellow)
you can see 3 small holes.
using wd40 few drops to holes.
then manually turn using your finger cw and ccw few times
you can feel smooth turning now.
then relabeling to hole side.
reassemble unit.
power on.
Now you can enjoy with your projector.
Jul 18, 2007 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
139 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
