Question about Refrigerators
Samsung bottom mount refrig icemaker freezes up
The icemaker ejects solid blocks of ice and fills the bin
  • 552 Answers
Try this link to fix your refrig ice maker.
Posted on Apr 02, 2008
My ice maker in my side by side refrig/freezer leaks water so that a solid block of ice is formed in the tray maker. This prevents dispensing of cubes. What can I do?.
The cause of that is the water inlet valve is not fully closing but instaed its staying open a little and seeping water through it all the time which is dripping into the storage bin for the icemaker and freezing all the ice into one huge block. To repair that the water inlet valve on the back of the ref. where the house water supply line attaches to would need to be replaced.
GENE
Sep 22, 2011 | Amana Refrigerators
I have a samsung rfg297aars refrig. I believe the water is leaking from the ice maker into the cube tray and running out and freezing in the cube dispenser and it is freezing the cubes together and...
you need to check the flapper in the door where the ice comes out,, if you take the ice bin out look down in the hole where the ice comes out,, if it is not sealing good it will let warm air come up the chute and melt the ice,, if it is sealing good,, then you need to check and see if the water fill tube( the one that goes into the icemake) is not froze up or has asomething blocking it
Jan 19, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Kenmore 795-75202400 icemaker problem.
Good day,
Either the water valve opens to fill the ice maker cavity, and doesn't shut off soon enough, causing the ice maker to overflow.
Normal file time is approx. 7 seconds.
This is the most common problem.
As well, it is possible the micro switch in the ice-maker that tells the valve to open and close has malfunctioned.
This is all based on the fact that the freezer maintains a normal temperature.
To test the freezer for consistency, place a plastic glass in the freezer half full of water.
Check it in 8 hours. It should be frozen solid. Then place the glass in a plastic bowl, and lay the glass on it's side. Recheck in 24 hours. The ice should remain in the glass.
If not, there is a problem with the refrigeration system.
Nov 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sep 05, 2009 | Whirlpool Refrigerators
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
