Question about Roper RES7646KQ Electric Dryer
Dryer suddenly quit working
I dried some clothes yesterday morning and dryer was working fine, then last night I went to take them out and dry some more and they were still damp. Nothing will work at all. Nothing will come on and I checked the fuses and even put new ones in. Checked the door switch and that's okay too. I need help in fixing this. The dryer is only 2 years old.
Please help
  • 4 more comments
  • Anonymous Apr 07, 2008
    Dryer not working. Put it on this morning and it started and later when I went to get the clothes they were damp. Tried to start it again but it would not work. Fuse box is fine. Light in dryer is on when I open it but dryer will not start at all. Please help!
  • Anonymous May 10, 2008
    dryer stopped working
  • amimar77 Jun 12, 2008
    My dryer also just stopped working yesterday!
    Must be sunspots--ha,ha!
    I have checked the fuse box & reset-have re-checked the lint trap (though I do this regularly) all to no avail.
    I mustbe said,that this dryer has given me faithful service for 13years-of course I was hoping it would last alttle longer.
  • Anonymous Jul 09, 2008
    how can you check the door switch
  • Anonymous Aug 30, 2008
    MY DRYER DID SAME THING BUZZER WENT OFF, WENT TO GET CLOTHES OUT, THEY WERE DRY BUT WHEN I PUT OTHER CLOTHES IN NOTHING HAPPENS. MINE IS ONLY 2 TO 21/2 YEARS OLD ALSO.
  • jill371 Aug 30, 2008
    I'M NOT HAPPY WITH THIS DRYER AT ALL
Having the same problem as above. Worked uptill yesterday. Now lights come on no activity. Please Help!!!
Posted on May 28, 2008
  • 549 Answers
Click this link for help.
Posted on Apr 02, 2008
2 Suggested Answers
  • 784 Answers
SOURCE: yesterday i was drying clothes and then all of a
Heating element needs to be replace. It made by several sections to produce heat. some section are bad so heating didn't come on with its full capacity.
Posted on Apr 25, 2010
Dryer will not operate
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your dryer.
Apr 04, 2017 | Whirlpool GEW9250P Electric Dryer
Samsung front load dryer will turn on but not spinning or drying. I was wiping it out and turning the drum I heard a snap sound.
I was cleaning mine and doing the same thing last night. Washed a load of clothes tonight and went to dry them and everything works on it except it won't spin or heat. Heard the same type of popping noise last night cleaning it out. Have you found any solutions? Mine is just over a year old. I did some reading and thing that the dryer belt came off its assembly possibly. Have you found a solution?
Jan 10, 2011 | Samsung Dryers
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
Dryer is heating but clothes are not drying.
Judging by the increasing moisture, your dryer vent is not venting the moisture to the outside. Check your vent pipe for blockages. I had a person a while back with a similar problem, and this person had a lint trap on the connection that went to the exterior of their house, so check that out as well.
May 08, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer gets hot, but not drying clothes
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
4. Moisture Sensor
Most units will have a moisture or dryness sensor as well that will fail. inspect the sensor for faults. replace if necessary.
Sep 05, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Clothes will not dry
Make sure the vent hose is clear of any clogs, then check to see if the element is coming on by pushing in the door switch with your finger and looking to the back of the inside of the dryer. You will also have to check the thermal fuse for continuity.
Jul 05, 2009 | Hotpoint NBXR333EGWW Dryer
My whirlpool heavy duty dryer just quit working all of a sudden
make sure you are getting power first then check to see if the belt is broken
Apr 21, 2009 | Dryers
Frigidaire Dryer hums wont turn on
motor-overheated. you might make sure the vent is clean.
Jan 05, 2008 | Dryers
Roper RES7646KQ Electric Dryer Logo
294 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
