Question about Astar LTV-2701 27 in. HD-Ready LCD Television
Help - dead TV
Does not always come on. When it does, has silver lines running up and down and sound usually comes on, then goes right back off. Makes crackling and popping sounds with a loud hum. Also, loud static sounds. Also, the logo that appears when the tv is turned on is not readable.
  • 58 Answers
The power supply in this model was terrible about having bad capacitors. The bad capacitors in this unit will have the top of teh can bowed out and browned. A qualified technician should be able to repair or replace the power supply.
Posted on Apr 02, 2008
Air in fuel ryobi tiller
you will have 2 lines at the tank. 1 is the supply line with one end having the fuel filter on it and sitting at the bottom of the tank. it generally runs to the inlet side of the carb. the output side of the carb usually goes to the primer bulb inlet, the last hose usually goes from the outlet of the primer bulb back to the fuel tank but only goes in 1/8 to 1/4 of an inch. it should only be in far enough to seal the hole and allow the fuel back in to the tank
Mar 29, 2013 | Ryobi Cultivator
Toshiba cf32h40 started last week the pic would go down to one thin line i would hit it on the side and it would come back ,but now thin line comes back when i hit and then goes away so i took off the back...
that silver box is called TV tuner (see picture ) ............ but in your case that is not the problem ......... after 4 or 5 yrs (depending on usuage ) in some TVs on mainboard & CRT tube's circuit board at some soldering joints cracks develops ... then due to loose contact TV behaves as you have described ........ when you are hitting that lightly on its side then these cracks at soldering joints are getting connected temporarly & for few seconds or minutes you are getting normal picture ....... so solution is most of the soldering joints on mainboard & on CRT circuit board has to be resoldered ....... only good tv service engineer can do this without shorting joints or damaging components..... so that silver box ( TV tuner ) is not the problem because when it gets deffective then you will get picture that comes when tv is switched on ---- usually it will be blue screen ......& also if you connect dvd you will get picture normally ...only thing is that you won't get picture from cable or antenna .............. vishnuswamy_25.jpg
Sep 01, 2011 | Toshiba CF32H40 32" TV
My samsung 50 inch projection tv makes the noise like it always has to power up,but the green lamp button flashes. the tv also has been making a loud buzzing noise for a couple of months now that comes and...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem...
Aug 22, 2011 | Televison & Video
My old 32 inch rca f32665 stopped working as we were watching it. no picture or sound and there is a sound coming from the back where the power cord goes in that sounds exactly like a cricket only its a...
The usual cause is a shorted horizontal output transistor. The way this chassis is designed, the supply makes 140 volts which is always on and applied to the transistor. The heavy load on the power supply causes it to make that chirping sound as it keeps trying to start, then shuts down right away.
The h-out is Q14401, RCA part number 237470. A 2SC5148 can replace it.
Jul 31, 2011 | RCA F32665 32" TV
I have a 32 inch crosley flatscreen lcd tv when i try to turn it on it makes a screeching sound and turns right off is it fixable
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.If otherwise, power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Jun 28, 2011 | Televison & Video
Plugged it in and it makes a clicking sound it won't do anything
nothing else ie no display, no lights if so dead main board no be economical for repair
if it has display ok then there is paper stuck, take out back door, check there..
also with the power off, check inside right up inside against far left and right walls of unit, paper gets stuck inside and then the bit that moves up and down along the silver bar(carriage and print head) slams the paper up against the wall. You need to reach in with two fingers and get it.
Nov 03, 2009 | Brother MFC 210C All-In-One InkJet Printer
I have a 42" Samsung DLP that makes noise that sounds like it's coming from the fan. The sound starts after the TV has been on for 20-30 minutes; it's a winding type sound and continues until after the TV...
These models usually suffer from a bad color wheel. You will know that the color wheel is at fault if the sounds goes away right when the lamp shuts off. Look at the back of the set and watch for the lamp to shut down. The color wheel is not a consumer replaceable item.
Aug 15, 2009 | Samsung DLP HL-P5663W 56" TV
Blank screen with lines
Looks like another dead CCD-chip. Not available from Fuji for diy.
Jan 26, 2009 | Fuji FinePix S5000 Digital Camera
Sony projection tv Model kp-61h510
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2007 | Toshiba 55H70 55" Rear Projection...
Sony kv35s66: No picture, just sound and red blinking
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Astar LTV-2701 27 in. HD-Ready LCD Television Logo
77 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
