Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
I need to know the correct settings. *My display will not fit in my screen *I think pictures appear to be streched *My font is somewhat out of focus My Monitor is a Samsung SyncMaster 932 BW
  • Samsung Master
  • 13,433 Answers
Native (Recommended) Resolution1280 x 1024 Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1280 x 960 · 1152 x 864 · 1152 x 870 · 720 x 400 · 640 x 350 Synchronization Range - Vertical56 - 75 Hz If my solution fixed your problem, could you give me a Fixya rateing? Becouse Im trying to reach the guru rank and its up to you if I get there or not.
Thanks alot!
Posted on Apr 02, 2008
  • 1 more comment
  • Ekse Apr 03, 2008
    The correct setting is
    1280 x 1024
    those others are resolutions that are functional on your screen.
  • Ekse Apr 03, 2008
    also use the automatic image setup function to addjust the screen.
  • Ekse Apr 06, 2008
    could you correct the rateing?
How to make letters on my screen darker to read ?
I'm thinking in settings for windows fonts you would select the font you want and then select bold . now this will be found in display/ appearance and under customize borders
Oct 02, 2014 | Dell Computers & Internet
Font size for reading messages in inbox is small. i want to increase its font size...
If your Defy is running one of the leaked Gingerbread (Android 2.3) ROMs, go to 'Menu > Settings > Display'. There, you'll find a 'Font size' dropdown menu. Select the size which suits you better.
Otherwise, I can think of two approaches to try to workaround the lack of a font size setting under the menu settings: 1) If you you have updated your device to (or if it already came with) Froyo (Android 2.2) - it is avalable on the Gingerbread leaked ROMs too - go to 'Menu > Settings > Accessibility', and tick both 'Accessibility' (this one you can leave ticked for good) and 'Zoom mode' (for this one you'll get a confirmation popup screen). A magnifying square will appear. Untick this setting to remove it. Whilst active, you can move it around by tapping, holding and dragging any of the 4 stripes on its edges. You can also set the magnification level, by tapping on either '-' or '+' signs. If you don't want to keep activating and deactivating it whenever you need it, you can leave it partially hidden, by dragging it to one of the screen's corners, the one which would bother you less.
2) Install 'Any Cut', by Jeff Hamilton, from the Android Market. Then, tap and hold any empty area on any of your home screens, and select 'Shortcuts > Any Cut > Activity'. Wait for the list to be updated, scroll down, tap 'Display' (attention: it's NOT 'Display settings') anf 'OK'. Tap that newly created shortcut. Tap the arrow right below 'Font', select 'Large', and tap 'OK'
Hope you are able to sort your problems out soon.
Anyway, please, let me know if I can assist you any further.
Regards, Carlos
Sep 25, 2011 | Motorola Mobility Defy Cell Phone
Icons and fonts are too large
hi,
  • To change font;
  • Right click on free space on the desktop.
  • Select properties then under display properties select Appearance.
  • At the bottom is font size option.Select normal.Save.
  • Icons:
  • Repeat font change procedure selecting settings under display properties.
  • Move to screen resolution and re-set it.[eg to 1024by768 pixels].Save.
Sep 16, 2011 | Microsoft Computers & Internet
Text to small
Change Your Font size.
1.Right Click on Desktop Click Properties "Display Properties will appear".
2.Click Appearance Change Font Size to Large Fonts or Extra Large Fonts.
3.Click Apply and Ok.
Or
Adjust Screen resolution.
1.Right Click on Desktop Click Properties.
2.Click Settings Adjust Screen resolution to 800 by 600 pixels
3.Apply and Ok.
Aug 13, 2011 | Computers & Internet
The Disks runs fine, never have any problems loading ANYTHING on it but when it loads PS1 Games the screen setting becomes quite odd. You dont see the whole screen (game screen) thus game play options dont...
It's not due to the compression at all. It's due to the limitations of the Snoy emulator. PS1 games output to 640×480 pixels (I'm using NTSC here, adjust if you live in PAL areas), but the PSP's screen is 480x272. In order to prevent weird streching, Sony desided to cut the screen size in half. So, the output of the ps1 emu is 320x240, exactly the same size that you see on your psp screen.
If you want to play with the streching, hit the home button, and under "Settings" you can adjust the screen size. Here is what the options do, as far as I know.
  • Fullscreen-changes the output full screen. "Letterboxes" (i.e., small black bars) it a bit to fit the 16x9 ratio.
  • Original-the 320x240 I just discribed above.
  • Normal-Streaches it a bit, and smooths out the picture
  • Zoom-Streches the picture even futher so that the width is equal to the width of the screen size.
Mind you, none of these modes ever make the emulator output a "better" picture with more pixels defined. They are all just streching of the 320x240 screen. I think this is because the psp is at it's limits, and rendering the extra pixels would lag the game too much.
Jan 03, 2010 | Video Game Consoles & Games
I cant get the whole picture to fit the screen. When I watch games the score is cut off.
This is most likely a setting on your TV, like stretch, or fit, or possibly on your cable box, or dish receiver. look at your dish or cable box settings and turn off any screen adjustments. Example under wide screen setting is strech , zoom, letterbox (choose letterbox).
The TV has these settings as well.
Aug 24, 2009 | Samsung LN46B650 46/49.5 in. LCD HDTV
My fonts are so large that I can't use some of my programs.
you could try going to "control panel" then personalisation and finally display settings look for the low high resolutions slider and adjust accordingly ( for windows vista)
this will adjust you monitor resolution so more items can fit on your screen
for windows xp i think from memory that it is "display settings" in the control panel you need i hope this helps in some way
Dec 22, 2008 | Acer Aspire 5100 Notebook
I want to change the image size and font size on my screen. When I push the menu button, I can't click on to any of the choices. Bill Kelly
You can not change the font and resolution through the monitor. For that Please Right click on desktop, Go to properties and click on. A separate window appears called Display Properties. There you can see the Themes, Desktop, Screen Saver, Appearance and Settings. To change the Desktop background click on Desktop and change the background. To change the font, click on Appearance and change some settings there. To change the image or to broaden the images click on Settings and change screen resolution. Thats it. After changing any of the settings you need to you need to click Apply which is present in the bottom right corner of the display settings. Then click ok.
Thank you.....
Sep 15, 2008 | Gateway Computers & Internet
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
Is it broken? Please help!
Hi it sound like you a problem called east west correction. But you will need to take it to a repair shop to fix it. My self i charge about £30 to fix this kind of fault. But dont know what others charg All the best Bob
Oct 17, 2007 | Bush 5693D 24" TV
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
180 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
