Question about Samsung Digimax S700 Digital Camera
Autofocus not working
I have a Digimax S700. It was working great but suddenly the auto-focus stopped working and now all pics are blurry. Do you have any advice?
  • 2 more comments
  • givensjoe Jun 25, 2008
    Mies doing the same thing
  • scuba6 Jul 14, 2008
    I have a Digimax S700 and it worked great until now. I get multiple horizontal lines in all the pictrues I take. Any hepl woud be appreciated.
  • Anonymous Jul 24, 2008
    Same problem. The autofocus suddenly stopped working. It appears to be an electronic failure with the autofocus. This is not caused by dirty lens or user malfunction.
  • Anonymous Apr 10, 2009
    same problem with my camera. suddenly all the pics are blurry. don't know what to do, might have to take it back to the shop
  • 57 Answers
Are you depressing the shutter button half way prior to snapping the shot you want. Also check to see if any of you setting are changed...if it's on auto and you still are have the same problem then your lens could be dirty.
Posted on May 27, 2008
6ya staff
SOURCE:
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
Aug 28, 2011 | Tamron SP AF 17-50mm f/2.8 XR Di II LD...
My auto focus will not work? Only manual. My photos are blurry when it is on autofocus. Why?
hi there,
i think your lens calibration is not match as it default so the auto focus can`t determine the object sharply
you should contact your official service center to get it fixed
thanks
Jan 09, 2011 | Canon Normal EF 50mm f/2.5 Compact Macro...
Brand new Canon EOS Rebel XS. Suddenly, image in the view finder is blurry. Auto focus seems to be working, and pictures are coming out fine. But sometimes, the autofocus focuses on the wrong thing, and so...
Next to the viewfinder ther is a diopter adjustment so you can change the focus in the viewfinder. this is so if you need glasses the camera can be set for you. Start by focusing the camera on something, then slide to turn the diopter adjustment until it looks sharp and try not to bump it.
Jun 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Blurry view
The simplest thing which might have gone wrong is that you mistakenly activated the macro function. Try taking a picture of, say, a flower from a few inches: if it's sharp, you're employing the camera's macro function and need to deactivate it.
I don't recall the DSC having a manual focus setting, but check it out. If you turned it on, you need to manually adjust the focus through the zoom control in order to get sharp pictures (or turn on autofocus, of course).
Otherwise, the auto-focusing software might be at fault. There are several autofocus settings available; try cycling them all and see if the problem is reversible.
If not, either the autofocus parameters are gone awry - I'm afraid the camera'll need servicing - or maybe a dirty lens is causing the autofocus to malfunction, in which case cleaning it would solve the problem. Frankly, it's unlikely - it would take a really cleverly positioned and greasy fingerprint to fool a modern focusing engine. But you might be lucky, and it's worth a check.
May 29, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Samsung digimax S700 battery problem
Clean the battery terminals and clean the metal contacts in your camera and insert your battery and check, whether you get low battery warning.
Hope this helps.
Jan 31, 2010 | Samsung Digimax S700 Digital Camera
Pictures are blurry.
Try pressing the shutter button half way to let it focus before you shoot. You also may want to make sure the camera is in auto mode and not set to any particular setting.
May 09, 2009 | Nikon COOLPIX S60 Digital Camera
Pictures either very white/red for Samsung Digimax S700 digital Camera
The iris in the center of the lens may be stuck open or damaged.
you can look inside the front a focus/zoom/ turn on off and see if it opens and closes.
Jan 27, 2008 | Samsung Digimax S700 Digital Camera
Blurry pics
Sounds like the auto focus mechanism in the camera needs to be cleaned and adjusted. The camera can be repaired yourself but it takes a great deal of mechanical know how and knowledge. Several links have already been posted on this issue.
I recommend you take the camera to a repair shop and have it done correctly.
Dec 10, 2007 | Samsung Digimax S630 Digital Camera
Autofocus has stopped working
Olympus web site for a repair or replace option.
Aug 04, 2007 | Olympus FE-140 Digital Camera
Auto-focus isn't working
Try checking your settings for the type of shot you are taking and for the type of focus......
type of shot is the dial on the top, and then:
1) menu, metering
and also check your autofocus mode
2)menu, autofocus; try the single autofocus, it might be set to continual
Also, you could try updating the firmware in your camera. You do this through the Nikon website.
Jan 23, 2007 | Nikon Coolpix 5900 Digital Camera
Samsung Digimax S700 Digital Camera Logo
150 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
